[postgis-users] Clip a table using a donut geometry
Júlio Almeida
julio.augusto.almeida at gmail.com
Mon May 9 04:32:40 PDT 2011
Hello,
I'm trying do clip some geometry tables (very big) using a donut geometry.
This geometry is the difference between a site area and a buffer area
arround de same site.
I wrote:
SELECT r.*, ST_Intersection(r.the_geom, m.the_geom) AS int_geom FROM
big_table AS r,
(SELECT ST_Difference(b.the_geom,a.the_geom) as the_geom from (select
st_buffer(a.the_geom,buffer_radius) as the_geom from
(select the_geom from designprocess.dp_zn_boundaries AS r where r.type
= site_name) as a) as b,
= site_name) as a) AS m
WHERE ST_Intersects(r.the_geom, m.the_geom);
but it's to slow.
In what order should I do the operation? Intersection, difference, buffer...
Can any one help me.
Thanks,
júlio
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110509/c68d8f35/attachment.html>
