[postgis-users] PostGIS Error: Loading with SPIT-Plugin-> MULTINULL
Florian Reimer gissolution at gmx.de
Tue May 10 01:19:33 PDT 2011
Hello,
we have a large Multipolygon Shapefile and try to load it from QGIS into PostGIS via the SPIT-Plugin. The file is recognized only as MULTINULL while it should be MULTIPOLYGON.
SELECT AddGeometryColumn('public','PA-Prop','the_geom',32617,'MULTINULL',2)
ERROR: Invalid type name - valid ones are:
GEOMETRY, GEOMETRYCOLLECTION, POINT,
MULTIPOINT, POLYGON, MULTIPOLYGON,
LINESTRING, MULTILINESTRING,
GEOMETRYCOLLECTIONM, POINTM,
MULTIPOINTM, POLYGONM, MULTIPOLYGONM,
LINESTRINGM, or MULTILINESTRINGM
CONTEXT: SQL statement "SELECT AddGeometryColumn('', $1 , $2 , $3 , $4 , $5 , $6 )"
PL/pgSQL function "addgeometrycolumn" line 4 at select into variables
There might be some error with Geometry, though the file works fine in QGIS and ArcGIS. Anyone had this problem before and might know something about it?
We are using:
Library:	1.1.6
Scripts:	1.1.6
GEOS:	3.0.0-CAPI-1.4.1
Proj:	Rel. 4.6.0, 21 Dec 2007
PostgreSQL 8.1.19 on i486-pc-linux-gnu, compiled by GCC cc (GCC) 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)
Thank you very much!
Florian
Empfehlen Sie GMX DSL Ihren Freunden und Bekannten und wir
belohnen Sie mit bis zu 50,- Euro! https://freundschaftswerbung.gmx.de
