[postgis-users] st_difference() problem?
Chris Hermansen
chris.hermansen at tecogroup.ca
Mon May 30 17:42:25 PDT 2011
Hmm. Blush. Now that I have posted and annoyed you all, I believe I see my
problem - I'm getting an outer product effect from my st_difference as it
visits each polygon.
So I need to go away and think about the join condition on those queries.
Sorry...
On Mon, May 30, 2011 at 5:06 PM, Chris Hermansen <
chris.hermansen at tecogroup.ca> wrote:
> Ladies and gentlemen;
> Nice to be back.
> I am wrestling with st_difference() and it is getting the better of me. I
> am hoping someone who has seen this before can help.
> I have two tables that are buffer polygons, built by PostGIS, around some
> linear features (trails and traplines).
> I am seeking to combine these two tables to produce a single set of
> polygons that shows areas that are inside the trail buffers, inside the
> trapline buffers, both, or neither.
> The pattern I am following is
> st_difference(btrail, btrapline)
> union
> st_intersection(btrail, btrapline)
> union
> st_difference(btrapline, btrail)
> The btrail table has 9 rows, all valid POLYGONs; the btrapline table has 18
> rows, all valid POLYGONs. Nothing self-overlaps. All have SRID of 3005.
> There is a place in the southwest of the area where one trapline buffer and
> one trail buffer cross over each other twice. No other features come close.
> If I copy just those two polygons into two separate test tables and use my
> difference/intersection/difference operation, I get the result I expect - 10
> polygons, none overlapping, where some are trapline-only, some are
> trail-only, and some are both trail and trapline. A visual inspection of
> the result in QGIS "makes sense".
> If I perform the same analysis on the full data set, I get a result that
> seems wrong - looking at the portion of the data related to those two
> features, instead of 10 polygons, I see 35 polygons. Many of these "result"
> polygons overlap each other. Visually (in QGIS again), I see what appears
> to be the two original input polygons covering a bunch of other polygons.
> I can of course post the data; I also have a few screen shots from QGIS
> saved as jpg files.
> This is from PostgreSQL 8.4.8 running on Ubuntu 10.10. The output from
> postgis_full_version() is
> POSTGIS="1.5.1" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September
> 2009" LIBXML="2.7.6" USE_STATS
> This is the code that produces the multiple overlapping result polygons
> with the full data set and seemingly normal results with the two test
> buffers.
> -- create the diff/int/diff on the full table
> drop table utrailtrapline;
> create table utrailtrapline (
> gid serial,
> istrail boolean,
> istrapline boolean);
> SELECT
> AddGeometryColumn('','utrailtrapline','the_geom','3005','POLYGON',2);
> insert into utrailtrapline (istrail, istrapline, the_geom)
> select
> istrail,
> FALSE as istrapline,
> (st_dump(st_difference(btrail.the_geom, btrapline.the_geom))).geom as
> the_geom
> from btrail, btrapline;
> select
> istrail,
> istrapline,
> (st_dump(st_intersection(btrail.the_geom, btrapline.the_geom))).geom as
> the_geom
> where st_intersects(btrail.the_geom, btrapline.the_geom);
> select
> FALSE as istrail,
> istrapline,
> (st_dump(st_difference(btrapline.the_geom, btrail.the_geom))).geom as
> the_geom
> Thanks in advance!
> Chris Hermansen
> TECO Natural Resource Group Limited
> 301 · 958 West 8th Avenue
> Vancouver BC CANADA · V5Z 1E5
> Tel +1.604.714.2878 · Cel +1.778.840.4625
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110530/74a9eb65/attachment.html>
