[postgis-users] How To Load SRTM Files into PostGIS
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Wed Oct 5 08:03:46 PDT 2011
Regina,
Any chance a build of PostGIS Raster on 2.0 work on PostGIS 1.5.3? Any other option to get PostGIS raster to work on 1.5.3?
Pierre
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Pierre Racine
> Sent: Tuesday, October 04, 2011 1:01 PM
> To: Puneet Kishor; PostGIS Users Discussion
> Subject: Re: [postgis-users] How To Load SRTM Files into PostGIS
> You may want to try what is available at :
> http://www.kyngchaos.com/software/postgres
> Otherwise, I think you might be able to compile a 2.0 version and install just the
> raster component over your PostGIS 1.5.3 without problem. With the shared
> libraries renaming from one version to the other, though, this night not work...
> Pierre
> > From: Puneet Kishor [mailto:punk.kish at gmail.com]
> > Sent: Tuesday, October 04, 2011 12:47 PM
> > To: PostGIS Users Discussion
> > Cc: Pierre Racine
> > On Oct 4, 2011, at 11:37 AM, Pierre Racine wrote:
> > > Hi there is a complete tutorial on how to load SRTM rasters in PostGIS here:
> > > http://trac.osgeo.org/postgis/wiki/WKTRasterTutorial01
> > This is great! Thanks. A question follows --
> > > You load them as true rasters. This implies you have PostGIS Raster installed.
> > It is not clear from http://trac.osgeo.org/postgis/wiki/WKTRaster
> > whether I can install PostGIS Raster with PostGIS 1.5.3, or if I have to go the
> PostGIS 2.0 way.
> > I already have a working copy of PostgreSQL 9.0.1/PostGIS 1.5.3
> > installed via MacPorts under /opt/local that I want to continue using.
> > So, I'd like to download only the PostGIS Raster source and compile it against
> my existing software.
> > How do I accomplish the above?
> > Puneet Kishor
> postgis-users mailing list
