[postgis-users] Error when building from source on mac os x 10.6
Nicolas Ribot
nicolas.ribot at gmail.com
Thu Oct 6 07:35:53 PDT 2011
> Dunno, something in the configuration of dependencies is all I can think of.
> With my Postgres 9.1.1 and current frameworks, this works:
> ./configure --with-pgconfig=/usr/local/pgsql-9.1/bin/pg_config \
> --with-geosconfig=/Library/Frameworks/GEOS.framework/unix/bin/geos-config \
> --with-projdir=/Library/Frameworks/PROJ.framework/unix \
> --with-raster --with-topology \
> --with-gdalconfig=/Library/Frameworks/GDAL.framework/Programs/gdal-config
Ok fine !
I will install current versions and test.
Thank you for the quick reply.
NIcolas
