[postgis-users] svn 7959 type "geometry" does not exist
Andreas Forø Tollefsen andreasft at gmail.com
Sat Oct 8 05:18:22 PDT 2011
Hi all.
Just reinstalled everything on my linux box.
Gdal 1.8.1, Geos 3.3.0 and related dependencies installed.
./configure, make and make install worked without problem for latest postgis
2.0 svn 7959,
but running the postgis.sql file is not working as usual (see below).
Any ideas?
Running the command:
psql -U postgres -d template_postgis -f
/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql
Results in:
SET
BEGIN
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:70: ERROR:
could not load library "/usr/lib/postgresql/8.4/lib/postgis-2.0.so":
/usr/lib/postgresql/8.4/lib/postgis-2.0.so: undefined symbol:
GEOSRelatePatternMatch
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:75: ERROR:
current transaction is aborted, commands ignored until end of transaction
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:82: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:90: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:95: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:101: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:107: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:112: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:117: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:122: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:136: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:144: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:147: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:157: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:163: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:169: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:175: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:181: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:187: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:193: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:199: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:205: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:211: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:218: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:224: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:233: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:238: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:245: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:253: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:258: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:265: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:271: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:276: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:284: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:290: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:296: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:302: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:308: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:314: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:323: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:328: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:335: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:341: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:347: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:352: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:358: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:365: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:373: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:381: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:401: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:421: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:429: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:434: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:439: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:444: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:449: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:454: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:464: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:470: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:476: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:482: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:487: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:497: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:512: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:518: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:527: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:533: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:539: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:545: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:551: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:557: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:563: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:569: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:575: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:581: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:587: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:597: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:604: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:610: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:615: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:621: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:627: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:634: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:640: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:646: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:652: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:658: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:664: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:670: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:676: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:682: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:688: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:694: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:700: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:706: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:712: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:718: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:724: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:730: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:736: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:742: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:748: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:777: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:787: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:793: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:799: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:805: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:815: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:821: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:827: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:833: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:842: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:848: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:854: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:863: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:870: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:877: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:883: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:889: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:895: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:902: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:908: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:915: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:924: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:930: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:936: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:945: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:951: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:958: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:964: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:970: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:976: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:982: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:988: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:994: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1000: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1006: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1012: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1018: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1024: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1030: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1036: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1042: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1048: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1054: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1060: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1066: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1072: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1078: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1084: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1090: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1096: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1102: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1108: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1118: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1124: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1131: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1137: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1143: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1149: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1155: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1161: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1167: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1173: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1179: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1185: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1191: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1197: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1203: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1210: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1217: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1224: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1227: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1233: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1239: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1334: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1346: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1358: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1365: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1371: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1378: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1391: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1474: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1623: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1786: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1804: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1822: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1883: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1905: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1927: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1964: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1976: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:1989: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2074: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2090: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2106: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2146: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2159: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2164: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2170: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2179: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2183: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2193: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2197: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2202: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2206: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2210: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2214: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2218: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2222: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2284: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2293: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2298: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2303: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2308: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2313: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2318: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2323: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2330: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2335: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2340: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2345: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2350: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2355: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2358: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2359: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2360: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2361: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2362: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2363: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2364: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2365: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2366: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2367: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2368: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2369: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2372: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2373: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2374: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2384: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2391: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2398: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2405: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2412: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2418: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2428: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2434: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2440: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2446: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2453: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2459: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2470: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2477: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2484: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2492: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2502: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2509: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2516: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2524: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2530: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2538: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2546: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2554: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2557: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2565: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2573: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2585: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2593: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2602: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2610: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2616: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2622: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2628: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2634: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2640: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2647: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2660: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2679: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2700: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2720: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2743: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2760: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2777: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2788: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2795: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2801: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2808: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2818: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2823: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2830: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2836: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2842: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2848: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2854: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2860: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2866: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2874: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2880: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2888: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2896: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2904: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2912: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2920: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2928: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2938: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2945: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2951: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2957: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2964: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2971: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2978: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2984: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2991: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:2998: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3005: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3012: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3019: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3026: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3033: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3040: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3047: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3053: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3060: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3067: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3074: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3081: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3088: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3095: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3103: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3109: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3115: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3122: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3128: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3134: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3140: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3147: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3153: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3162: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3168: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3174: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3180: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3186: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3192: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3201: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3207: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3213: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3222: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3229: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3236: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3243: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3250: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3257: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3264: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3272: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3281: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3287: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3293: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3300: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3307: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3314: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3325: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3331: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3337: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3343: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3349: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3355: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3361: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3371: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3377: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3386: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3392: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3398: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3404: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3410: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3416: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3422: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3428: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3434: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3440: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3446: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3456: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3466: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3472: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3478: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3484: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3490: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3496: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3502: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3508: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3514: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3519: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3525: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3531: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3537: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3543: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3549: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3555: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3561: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3567: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3573: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3578: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3584: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3589: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3595: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3606: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3618: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3628: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3638: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3648: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3658: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3664: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3670: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3681: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3691: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3698: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3704: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3714: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3724: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3730: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3736: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3746: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3756: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3762: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3768: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3779: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3790: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3796: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3802: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3808: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3814: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3824: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3834: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3844: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3854: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3864: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3874: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3884: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3894: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3904: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3914: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3924: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3935: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3945: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3955: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3965: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3975: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3985: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:3996: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4006: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4016: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4027: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4038: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4050: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4060: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4066: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4071: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4076: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4081: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4086: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4091: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4096: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4101: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4145: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4182: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4228: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4280: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4287: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4294: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4301: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4334: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4367: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4374: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4379: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4384: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4443: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4461: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4506: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4568: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4589: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4646: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4668: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4676: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4682: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4688: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4698: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4704: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4710: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4748: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4797: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4820: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4826: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4850: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4856: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4862: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4868: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4874: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4887: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4897: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4903: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4912: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4919: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4922: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4928: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4934: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4937: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4939: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4946: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4953: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4959: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4965: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4971: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4978: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4984: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4990: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:4996: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5002: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5024: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5030: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5033: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5039: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5042: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5052: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5058: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5064: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5070: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5076: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5082: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5088: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5094: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5100: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5106: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5114: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5131: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5143: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5148: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5153: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5158: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5163: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5168: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5178: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5184: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5190: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5196: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5201: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5210: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5226: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5232: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5238: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5245: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5256: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5262: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5268: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5275: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5281: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5287: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5293: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5299: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5305: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5317: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5323: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5329: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5336: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5342: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5348: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5355: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5366: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5372: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5378: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5385: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5391: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5397: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5403: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5409: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5422: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5430: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5436: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5443: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5450: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5457: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5463: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5470: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5477: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5484: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5491: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5498: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5505: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5513: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5519: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5527: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5534: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5541: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5548: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5555: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5561: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5568: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5574: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5580: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5586: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5593: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5599: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5606: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5624: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5630: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5636: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5642: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5648: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5654: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5660: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5678: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5687: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5703: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5715: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5724: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5821: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5836: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5851: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5868: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5885: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5897: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5903: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5909: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5915: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5921: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5927: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5933: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5939: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5945: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5951: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5969: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5980: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5985: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:5990: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6108: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6187: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6339: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6349: ERROR:
block
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6355: ERROR:
block
ROLLBACK
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6362: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6363: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6364: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6365: ERROR:
DROP FUNCTION
DROP FUNCTION
DROP FUNCTION
DROP FUNCTION
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6375: ERROR:
type "box2d" does not exist
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6376: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6377: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6378: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6379: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6380: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6381: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6382: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6383: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6384: ERROR:
type "geography" does not exist
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6385: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6386: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6387: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6388: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6389: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6390: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6391: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6392: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6393: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6394: ERROR:
DROP FUNCTION
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6396: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6397: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6398: ERROR:
type "box3d" does not exist
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6399: ERROR:
type "box3d_extent" does not exist
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6400: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6401: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6402: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6403: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6404: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6405: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6406: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6407: ERROR:
DROP FUNCTION
DROP FUNCTION
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6410: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6411: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6412: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6413: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6414: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6415: ERROR:
DROP FUNCTION
DROP FUNCTION
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6418: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6419: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6420: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6421: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6422: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6423: ERROR:
type "geometry[]" does not exist
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6424: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6425: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6426: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6427: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6428: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6429: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6430: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6431: ERROR:
DROP FUNCTION
DROP FUNCTION
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6435: ERROR:
DROP FUNCTION
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6437: ERROR:
DROP FUNCTION
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6439: ERROR:
type "spheroid" does not exist
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6440: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6441: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6442: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6443: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6444: ERROR:
psql:/usr/share/postgresql/8.4/contrib/postgis-2.0/postgis.sql:6445: ERROR:
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111008/b8510415/attachment.html>
