[postgis-users] ST_Intersection Raster error
joel brown
joel at loticwater.com
Tue Oct 11 17:59:27 PDT 2011
Hi all, I am just starting to experiment with postgis 2.0 and its raster
support. When I run the following query:
select st_intersection(r.rast, v.geom)
from ned r, test_line v
where st_intersects(r.rast, v.geom)
I get this error:
ERROR: lower bound of FOR loop cannot be null
CONTEXT: PL/pgSQL function "_st_intersects" line 103 at FOR with integer
loop variable
PL/pgSQL function "st_intersection" line 4 at assignment
SQL function "st_intersection" statement 1
My build is SVN revision 7959. The ned table consists of about 1800 100x100
tiles. The test_line table contains one record with a linestring geometry.
Both the tiles and the linestring are in the same projection (EPSG 4326).
Does anyone have any insights into what might be going on here?
Thanks,
Joel
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111011/d38ef6d2/attachment.html>
