[postgis-users] Query slow down, never completes
Andreas Forø Tollefsen andreasft at gmail.com
Wed Oct 12 00:52:58 PDT 2011
Yes, I did a version of the query where i terminated the connection in the
loop after one year, and then reconnected to the server for each year in the
query.
This did not change anything, and the query still halted on the same year.
Like this:
# For each year calculate the distance to border and insert into the
borddist table
yearlist = range(1946, 2009, 1)
for x in yearlist:
    db1 = psycopg2.connect("host=192.168.1.186 dbname=priogrid user=postgres
password=postgres")
    cur = db1.cursor()
    print str(time.ctime())+ " Creating borddist for year "+str(x)+"."
    cur.execute("INSERT INTO borddist(gid, gwcode, gridyear, borddist)
SELECT a.gid, a.gwcode, "+str(x)+", MIN(ST_Distance(ST_Transform(a.centroid,
954010), ST_Transform(b.geom, 954010)))/1000 AS borddist \n" \
                "FROM priogridall_geom a, cshapes b, cshapes c WHERE
a.gwcode != b.gwcode AND b.gwsyear <= "+str(x)+" AND b.gweyear >= "+str(x)+"
\n" \
                "and a.gwcode = c.gwcode and st_intersects(b.geom, c.geom)
AND a.gridyear = "+str(x)+" GROUP BY a.gid, a.gwcode;")
    db1.commit()
    cur.close()
    db1.close()
db1.commit()
print str(time.ctime())+ " Done"
cur.close()
db1.close()
I also followed your suggestion to not write any data. Just do a select,
without any select into or insert into.
The same problem occurred.
Script:
    cur.execute("SELECT a.gid, a.gwcode, "+str(x)+", "\
                "MIN(ST_Distance(a.centroid, b.geom)) "\
                "AND a.gwcode = c.gwcode and ST_Intersects(b.geom, c.geom)
    db1.commit()
Thank you very much for looking into this. I have used over two weeks to try
to figure this out.
The only thing i can do is to run the script for 1/2 the years, then restart
the server "service postgresql restart" and then run it for the next 1/2.
Some memory and cpu information.
Here is how it looks in free -m and top when the script have halted.
             total       used       free     shared    buffers     cached
Mem:     5977       5371        605          0        139       4735
-/+ buffers/cache:   495       5481
Swap:    6075          1       6074
top - 09:51:07 up 1 day, 18:44,  2 users,  load average: 1.88, 1.32, 1.20
Tasks: 165 total,   2 running, 162 sleeping,   0 stopped,   1 zombie
Cpu(s): 53.2%us,  1.3%sy,  0.0%ni, 45.5%id,  0.0%wa,  0.0%hi,  0.0%si,
 0.0%st
Mem:   6120848k total,  5505868k used,   614980k free,   143004k buffers
Swap:  6221820k total,     1468k used,  6220352k free,  4849556k cached
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
 7810 postgres  20   0 2264m 1.0g 1.0g R  100 18.0 988:09.39 postgres
 1417 andreas   20   0  163m  39m  14m S    3  0.7   3:27.13 compiz
  907 root      20   0 57092  34m  10m S    2  0.6   1:48.73 Xorg
 7088 andreas   20   0 93012  15m  10m S    2  0.3   0:02.80 gnome-terminal
10772 andreas   20   0  204m  96m  23m S    2  1.6   0:19.88 chromium-browse
 1525 andreas   20   0  100m  15m 9548 S    1  0.3   5:11.16 unity-panel-ser
10675 andreas   20   0  308m  50m  29m S    1  0.8   0:07.55 chromium-browse
 1088 root      20   0  9420 1632  964 S    0  0.0   0:07.01 nmbd
 1389 andreas   20   0  5552 2740  700 S    0  0.0   1:17.77 dbus-daemon
10825 andreas   20   0 35836  19m 6276 S    0  0.3   0:02.94 idle-python2.6
    1 root      20   0  3040 1780 1220 S    0  0.0   0:02.16 init
    2 root      20   0     0    0    0 S    0  0.0   0:00.01 kthreadd
    3 root      20   0     0    0    0 S    0  0.0   0:07.21 ksoftirqd/0
    6 root      RT   0     0    0    0 S    0  0.0   0:00.00 migration/0
    7 root      RT   0     0    0    0 S    0  0.0   0:00.00 migration/1
    9 root      20   0     0    0    0 S    0  0.0   0:03.00 ksoftirqd/1
   11 root       0 -20     0    0    0 S    0  0.0   0:00.00 cpuset
After i restart the postgresql service:
Mem:     5977       4319       1657          0        139       3687
-/+ buffers/cache:   492       5484
Swap:         6075       1       6074
top - 09:52:33 up 1 day, 18:46,  2 users,  load average: 1.42, 1.33, 1.22
Tasks: 164 total,   1 running, 162 sleeping,   0 stopped,   1 zombie
Cpu(s):  1.3%us,  0.3%sy,  0.0%ni, 98.3%id,  0.0%wa,  0.0%hi,  0.0%si,
 0.0%st
Mem:   6120848k total,  4430204k used,  1690644k free,   143092k buffers
Swap:  6221820k total,     1468k used,  6220352k free,  3776880k cached
  907 root      20   0 52996  30m 6728 S    1  0.5   1:49.78 Xorg
 1417 andreas   20   0  163m  39m  14m S    1  0.7   3:28.43 compiz
  194 root      20   0     0    0    0 S    0  0.0   0:48.68 usb-storage
 1447 root      20   0  5564 1000  712 S    0  0.0   0:23.28 udisks-daemon
 1525 andreas   20   0  100m  15m 9548 S    0  0.3   5:11.66 unity-panel-ser
 1583 andreas   20   0 33552  16m 8984 S    0  0.3   0:03.21 applet.py
 7039 andreas   20   0 44240  23m 6304 S    0  0.4   0:04.51 idle-python2.6
 7088 andreas   20   0 93264  15m  10m S    0  0.3   0:03.28 gnome-terminal
2011/10/11 Sandro Santilli <strk at keybit.net>
> On Tue, Oct 11, 2011 at 05:12:24PM +0200, Andreas Forø Tollefsen wrote:
> > Hi Sandro,
> > What i find strange is that it stops processing at different years on my
> > desktop and my laptop. While my desktop stops processing at 1980, my
> slower
> > laptop goes on to 1991 before halting.
> > I also tried with different postgresql.conf shared_buffers settings
> without
> > making any difference.
> > Therefore it is hard to reproduce this for a single year. I can easily
> > process 1980 or 1991 if just running the script for that year.
> But you mentioned you had stopped the backend and restarted for each year ?
> Does the problem still occur if you avoid writing any table (could be an
> I/O
> issue) ?
> --strk;
>  ()   Free GIS & Flash consultant/developer
>  /\   http://strk.keybit.net/services.html
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111012/74574732/attachment.html>
