[postgis-users] ST_Intersect(raster, raster)
Joan
wamaithajoan at gmail.com
Thu Oct 13 07:27:08 PDT 2011
Hello,
When I run the following query I get the error below. Anyone knows a
solution?
select ST_Intersects(forest.rast, dem.rast) from forest join dem on 1=1
limit 1;
ERROR: function st_intersects(raster, raster) is not unique
LINE 1: select ST_Intersects(forest.rast, dem.rast) from forest join...
HINT: Could not choose a best candidate function. You might need to add
explicit type casts.
********** Error **********
SQL state: 42725
Hint: Could not choose a best candidate function. You might need to add
Character: 8
Regards
Joan W
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111013/723dc129/attachment.html>
