[postgis-users] compiling PostGIS 2.0 SVN on OS X Lion
Nicolas Ribot nicolas.ribot at gmail.com
Sun Oct 16 03:15:41 PDT 2011
> punkish at Lucknow ~/Projects/postgis-svn$autoconf
> configure.ac:20: error: possibly undefined macro: AC_PROG_LIBTOOL
>      If this token and others are legitimate, please use m4_pattern_allow.
>      See the Autoconf documentation.
> configure.ac:39: error: possibly undefined macro: AC_LIBTOOL_COMPILER_OPTION
> configure.ac:555: error: possibly undefined macro: AM_GNU_GETTEXT
> configure.ac:599: error: possibly undefined macro: AC_PROJ_VERSION
> configure.ac:632: error: possibly undefined macro: AM_PATH_GTK_2_0
> suggestions?
Hi Puneet,
I used these commands with the latest Kyngchaos packages and was able
to build Postgis 2.0:
export CPPFLAGS=-I/usr/local/pgsql-9.1/include/server
export LDFLAGS=-L/usr/local/pgsql-9.1/lib
export CPATH=/usr/local/pgsql-9.1/include/server/
export LIBRARY_PATH=/usr/local/pgsql-9.1/lib
./configure \
--prefix=$HOME/bin/postgis-2.0 \
--with-pgconfig=/usr/local/pgsql-9.1/bin/pg_config \
--with-geosconfig=/Library/Frameworks/GEOS.framework/unix/bin/geos-config \
--with-projdir=/Library/Frameworks/PROJ.framework/unix \
--with-raster \
--with-topology \
--with-gdalconfig=/Library/Frameworks/GDAL.framework/Programs/gdal-config
make clean && make
sudo make install
After that, I modified the path to avoid calling the default
/usr/bin/psql Mac version.
Nicolas
