[postgis-users] Read WorldClim gridded data in QGIS
uyen dang ruoisua at yahoo.com
Sun Oct 16 08:14:24 PDT 2011
Hello, have any one try to read WorldClim gridded data in QGIS?
I first convert the generic grid format to ESRI Ascii using DIVA-GIS, but i can not get up the color map.
Following is Information that i get from the gdalinfo command :
Driver: AAIGrid/Arc/Info ASCII Grid
Files: /media/Logiciel/telechargement/tmean_esri/tmean1.asc
Size is 8640, 3600
Coordinate System is `'
Origin = (-180.000000000003013,90.000000000000000)
Pixel Size = (0.041666666666667,-0.041666666666667)
Corner Coordinates:
Upper Left  (-180.0000000,  90.0000000)
Lower Left  (-180.0000000, -60.0000000)
Upper Right ( 180.0000000,  90.0000000)
Lower Right ( 180.0000000, -60.0000000)
Center      (  -0.0000000,  15.0000000)
Band 1 Block=8640x1 Type=Int32, ColorInterp=Undefined
  NoData Value=-9999
Do you have any suggestions ?
Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111016/41104f08/attachment.html>
