[postgis-users] Support in ST_ConvexHull syntax
Gery .
gamejihou at hotmail.com
Wed Oct 19 06:23:28 PDT 2011
Hello,
After reading a while, I don't get the polygon from my points table (splitbeam_point) I think it is possible through the following script:
DROP TABLE testone;
CREATE TABLE testone(
ID INT
SELECT AddGeometryColumn('public', 'testone', 'geom', 4326, 'POLYGON', 2);
CREATE INDEX testone_geom ON testone USING GIST ( geom );
INSERT INTO testone SELECT ST_ConvexHull(ST_Collect(geom)) AS testone_geom FROM splitbeam_point GROUP BY ID;
I get this error message: column "id" is of type integer but expression is of type geometry
and after I insert ::numeric,4 in the ST_ConvexHull statement, I get: ERROR: cannot cast type geometry to numeric
How can I circumvent this error?
Any support is very welcome, thanks,
Gery
