[postgis-users] pgsql2shp error
Christian Jauvin
cjauvin at gmail.com
Sat Oct 22 08:46:59 PDT 2011
I am trying to use pgsql2shp on Ubuntu 10.04 64-bit:
$ dpkg -l | grep postgis
ii postgis 1.5.2-2~lucid1
ii postgresql-8.4-postgis 1.5.2-2~lucid1
The problem:
$ pgsql2shp geo_db "select * from sdr_2001"
Preparing table for user query... Done.
Initializing... Geometry type unknown (have you enabled postgis?)
WARNING: Cannot determine spatial reference (empty table or unknown
spatial ref). No prj file will be generated.
Done (postgis major version: 1).
Output shape: Polygon
Dumping: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX [4700 rows].
"geo_db" is a perfectly valid PostGIS database:
geo_db=# select postgis_full_version();
POSTGIS="1.4.0" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23
September 2009" USE_STATS
Any idea about what I'm doing wrong?
Thanks,
Christian
