[postgis-users] Inserting New SRID into spatial_ref_sys Table
elliott at cpi.com
elliott at cpi.com
Mon Oct 24 12:55:26 PDT 2011
No, the rasters in the srtm3 table are in SRID 4326.
I want to retrieve the altitude value in SRID 4978.
> Just to double check:
> -rasters in the srtm3 table are also in the SRID 4978?
> -What if you do:
> SELECT ST_X(ST_Transform(ST_SetSRID(ST_Point(126.5,37.5), 4326), 4978))),
> ST_Y(ST_Transform(ST_SetSRID(ST_Point(126.5,37.5), 4326), 4978)))
> -It might also be that the point actually does not intersects with the
> image. What if you add
> WHERE ST_Intersects(rast, ST_Transform(ST_SetSRID(ST_Point(126.5,37.5),
> 4326), 4978)))
> To your query?
> Pierre
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-
>> bounces at postgis.refractions.net] On Behalf Of elliott
>> Sent: Monday, October 24, 2011 1:11 PM
>> To: PostGIS Users Discussion
>> Subject: [postgis-users] Inserting New SRID into spatial_ref_sys Table
>> I have inserted a new SRID (4978) into the spatial_ref_sys table.
>> However, when I run the following query, it gives an out of range error.
>> What I
>> want to do is get the altitude in ECEF coordinates, but perhaps my query
>> is not
>> correct.
>> select ST_Value(rast, ST_Transform(ST_SetSRID(ST_Point(126.5,37.5),
>> 4326), 4978)) from srtm3 where filename='N37E126.hgt';
>> ERROR: value "-3616486790" is out of range for type integer
>> CONTEXT: PL/pgSQL function "st_world2rastercoordx" while casting return
>> value to function's return type
>> PL/pgSQL function "st_value" line 13 at RETURN
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
