[postgis-users] [OT] stored procedure performance [SOLVED]
Stephen Woodbridge woodbri at swoodbridge.com
Mon Oct 24 13:26:25 PDT 2011
Sorry if you already got this on the pgRouting list, it was supposed to
get posted here. But for people here I have already solved the original
post and I thought it might be of interest to poeple here if you are
working with stored procedures that return records.
OK, googling about seems like the problem below is normal but bad
behavior. I did find a way to work around this bad behavior.
This is BAD (function called 6 times):
select a.*, (b).* from (select x, y, imt_rgeo_countyzip(x,y) as b from
(select -79.2723 as x, 41.2393 as y) as c) as a;
This is GOOD (function called 1 time):
(select -79.2723 as x, 41.2393 as y) as c offset 0) as a;
It is amazing what you can find in Google :)
-Steve
On 10/24/2011 12:04 PM, Stephen Woodbridge wrote:
> Hi All,
> This is a little off topic, but I did find this issue developing a
> postgis related stored procedure.
> This is a simple reverse geocoder and it works fine, but here is the
> issue and this potentially impacts all procedures that return a record.
> So here is the basic query. I added some raise notice to show whats
> happening.
> select * from imt_rgeo_countyzip(-79.2723,41.2393);
> "Clarion";"PA";"42031";"16225";0;0
> NOTICE: calling imt_rgeo_countyzip
> CONTEXT: PL/pgSQL function "imt_rgeo_countyzip" line 8 at assignment
> NOTICE: rr: (Clarion,PA,42031,0), radius: 0.0013
> NOTICE: zip: (16225,0), radius: 0.0013
> Total query runtime: 81 ms.
> 1 row retrieved.
> So here is the problem! If you call the function this way, it appears to
> get called once for each field in the returned record. So if you have 6
> fields it actually executes the function 6 times!!!! and the cost goes
> up by 6X to 415 ms from 81 ms.
> select (imt_rgeo_countyzip(-79.2723,41.2393)).*;
> Total query runtime: 415 ms.
> 1 row retrieved.
> Thoughts,
> -Steve
Pgrouting-users mailing list
Pgrouting-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/pgrouting-users
