[postgis-users] ST_DWithin-- unexpected behavior?
Stephen V. Mather svm at clevelandmetroparks.com
Tue Oct 25 08:03:58 PDT 2011
Hi All,
                Running 1.3.5 still :).  Found some unexpected (to me), but
pleasant behavior with ST_DWithin.  What we're doing is creating a function
that we can use to randomize a point within a minimum and maximum bounds.
Our original approach was to generate the geometry of the difference of two
buffers (a donut, if you will) and then place a random point within that.
Better to test with ST_DWithin directly then buffer, so we rewrote:
BEGIN
                xmin = ST_XMin(geom) - dough;
                deltax = ST_XMax(geom) - xmin + dough;
                ymin = ST_YMin(geom) - dough;
                deltay = ST_YMax(geom) - ymin + dough;
                WHILE i < itermax LOOP
                                i = i + 1;
                                pointx = xmin + deltax * random();
                                pointy = ymin + deltay * random();
                                returnpoint = ST_SetSRID( ST_MakePoint(
pointx, pointy ), ST_SRID(geom) );
                EXIT WHEN
                                                ST_DWithin( returnpoint,
geom, dough )
        AND NOT
geom, nut );
                END LOOP;
                IF i > itermax THEN
                                RAISE NOTICE 'Reached maximum iterations
without placing point inside donut.';
                END IF;
                RETURN returnpoint;
END;
The puzzling part is that even if the parameters are passed out of order,
i.e. the inner ring is passed for the outer ring and vice versa, we get a
fine result.  It's a nice unexpected behavior, but unexpected none-the-less.
Anyone have any thoughts on why this works?  Full function below:
http://www.clemetparks.com/images/esig/cmp-ms-90x122.pngStephen Mather
Geographic Information Systems (GIS) Manager
(216) 635-3243
 <http://www.clemetparks.com/> clevelandmetroparks.com
CREATE OR REPLACE FUNCTION ST_Donut
                ( geom Geometry,
                dough DOUBLE PRECISION,
                nut DOUBLE PRECISION,
                itermax INTEGER)
                RETURNS Geometry
                AS $$
DECLARE
                xmin DOUBLE PRECISION;
                ymin DOUBLE PRECISION;
                deltax DOUBLE PRECISION;
                deltay DOUBLE PRECISION;
                pointx DOUBLE PRECISION;
                pointy DOUBLE PRECISION;
                returnpoint Geometry;
                i INTEGER := 0;
                nut1 DOUBLE PRECISION;
                dough1 DOUBLE PRECISION;
BEGIN
                                i = i + 1;
                EXIT WHEN
geom, dough )
        AND NOT
geom, nut );
                END LOOP;
                IF i > itermax THEN
                END IF;
                RETURN returnpoint;
END;
$$ LANGUAGE plpgsql;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111025/2ca12114/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111025/2ca12114/attachment.png>
