[postgis-users] polygon Extraction problem
Clay, Bruce
bclay at ball.com
Wed Oct 26 19:06:37 PDT 2011
I have a table of points extracted from a raster file. I perform the following SQL on the table
CREATE TABLE weather_poly as
SELECT(pixel_val, ST_Transform(ST_Union(ST_Buffer(shape, 0.1)),4326)) FROM
weather_points GROUP BY pixel_val;
The resulting polygon is 13 multi-polygons one for each pixel value instead of one polygon for every cluster of points.
I can run the following SQL select ST_Dump(shape) from weather_poly a to break the polygons so they appear as separate polygons in Postgresql data view.
When I try to view them in QGis the table does not show on the list of available PostGis layers. The properties of the table in Postgresql show the geometry to be ST_Dump not polygon.
Is there a way to split the multi-polygon into individual polygons or to build the original polygons separatly so they will show in QGis and be accessable as such by GDAL based applications?
Bruce
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111026/375870de/attachment.html>
