[postgis-users] no row selected on spatial query
Ben Madin
lists at remoteinformation.com.au
Sun Oct 30 15:07:21 PDT 2011
Puneet - I think this can happen if you load a shapefile that is projected into a table specifying a lat long srid. I don't think the definition restricts the range of units.
You will have to change the column definition I guess.
cheers
Ben
On 28/10/2011, at 8:06 AM, Puneet Kishor wrote:
> A brief follow-up on this --
> On Oct 27, 2011, at 5:57 PM, Puneet Kishor wrote:
>> I inherited two tables like so
>> db=# select ST_Extent(the_geom) from t1;
>> st_extent
>> BOX(-180 5.67656603969958,180 89.9999951703269)
>> (1 row)
>> db=# select ST_Extent(the_geom) from t2;
>> st_extent
>> BOX(-3666182.8927 1296299.9824,4440422.8742 8820425.3008)
>> (1 row)
>> I want to convert t2 to match t1. So, I tried the following --
>> db=# UPDATE t2 SET the_geom = ST_Transform(the_geom, 4326);
>> UPDATE 1354
>> But that didn't do it.
>> st_extent
>> (1 row)
>> What do I do to transform t2 so its geometry matches t1?
> Turns out t2 was loaded from a shapefile using shp2pgsql using SRID 4326. Its table definition is like so
> CREATE TABLE t2
> gid serial NOT NULL,
> objectid integer,
> type integer,
> the_geom geometry,
> CONSTRAINT t2_pkey PRIMARY KEY (gid ),
> CONSTRAINT enforce_dims_the_geom CHECK (st_ndims(the_geom) = 2),
> CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) = 'POINT'::text OR the_geom IS NULL),
> CONSTRAINT enforce_srid_the_geom CHECK (st_srid(the_geom) = 4326)
> WITH (
> OIDS=FALSE
> So, in spite of the `enforce_srid_the_geom` CONSTRAINT which should restrict geometry to 4326, seems like meter values got inserted into the table. How is that possible?
> And, in any case, how can I repair this?
> Puneet Kishor
> postgis-users mailing list
