[postgis-users] smoothing data - David Bitner method
Gery .
gamejihou at hotmail.com
Mon Apr 2 14:31:55 PDT 2012
I was searching on internet a way to smooth lines in postgis, something different to just using simplify or the st_simplify approach, and I found an impressive method developed by Mr. David Bitner, this is the post: http://postgis.refractions.net/pipermail/postgis-users/2010-October/030264.html, and the output PNG is very impressive.
I have a very similar problem as showed by Mr. Bitner, but just having only longitude and latitude (two parameters instead of 4 as in the link above). I tried already the simplify command and it doesn't give the smooth I want, because it doesn't produce curves, even though I played with almost all the reasonable values in the tolerance. Has anyone used this neat script succesfully on longitude/latitude (e.g., navigation) tracks? or is there some command already like that in postgis 1.5.3.??
Thanks in advance for any help,
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120402/790f72e1/attachment.html>
