[postgis-users] How to set the parent schema of postgis 2.0 to "postgis" instead of "public"
Andy Colson
andy at squeakycode.net
Mon Apr 2 19:40:43 PDT 2012
On 04/02/2012 06:40 PM, THX1138 wrote:
> Hello All,
> I am attempting to keep my non-gis information separate from my gis
> information and thus would like to create a separate postgis schema but I
> have run into some problems.
> I ran the following commands to move the data into a new schema:
> CREATE schema postgis;
> ALTER EXTENSION postgis SET SCHEMA postgis;
> SET search_path TO "$user",public,postgis
> Yet, for some reason when I run a spatial query such as "select
> st_makevalid(geom) from jurisdictions", I get the following error:
> ERROR: function st_makevalid(postgis.geometry) does not exist
> LINE 1: select st_makevalid(geom) from jurisdictions
> HINT: No function matches the given name and argument types. You might need
> to add explicit type casts.
> Can anyone point me in the right direction as to how to fix this?
> I am still using beta 3, so perhaps this error has been fixed in later
> versions.
> Another problem might be that I have legacy functions installed in the
> public schema and that they somehow conflict with postgis 2.0 being
> installed in the postgis schema. If this is the case, is it possible to
> import those functions into the postgis schema as well (or their own
> schema)?
> Thanks
> THX1138
> View this message in context: http://postgis.17.n6.nabble.com/How-to-set-the-parent-schema-of-postgis-2-0-to-postgis-instead-of-public-tp4680493p4680493.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
Not sure, but, maybe you need to create it up front:
CREATE extension postgis with SCHEMA postgis;
-Andy
