[postgis-users] How to set the parent schema of postgis 2.0 to "postgis" instead of "public"
Paragon Corporation
lr at pcorp.us
Mon Apr 2 21:56:27 PDT 2012
Actually I'm not absolutely sure its the same thing. I'll put in a ticket
myself, but it might be related.
When I move rc1 (which I had upgraded from beta2) to another schema I am
left with two functions in public.
st_dump, st_ivaliddetail
I think this is similar to what is happening to you. I suspect that these
may have been dropped from the extension and never readded possibly because
their signature changed and they shouldn't be there or there is something
wrong with create extension that is leaving these out.
If I upgrade a clean rc2 -- there is nothing left in public.
Those functions I see now are marked as taking postgis.geometry as input. My
st_makevalid still works though and is moved to postgis.schema. So you
might want to just upgrade to rc2
Do you see st_makevalid in public?
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Andy Colson
> Sent: Monday, April 02, 2012 10:41 PM
> To: PostGIS Users Discussion
> Cc: THX1138
> Subject: Re: [postgis-users] How to set the parent schema of
> On 04/02/2012 06:40 PM, THX1138 wrote:
> > Hello All,
> > I am attempting to keep my non-gis information separate from my gis
> > information and thus would like to create a separate postgis schema
> > but I have run into some problems.
> > I ran the following commands to move the data into a new schema:
> > CREATE schema postgis;
> > ALTER EXTENSION postgis SET SCHEMA postgis; SET search_path TO
> > "$user",public,postgis
> > Yet, for some reason when I run a spatial query such as "select
> > st_makevalid(geom) from jurisdictions", I get the following error:
> > ERROR: function st_makevalid(postgis.geometry) does not
> exist LINE 1:
> > select st_makevalid(geom) from jurisdictions
> > HINT: No function matches the given name and argument types. You
> > might need to add explicit type casts.
> > Can anyone point me in the right direction as to how to fix this?
> > I am still using beta 3, so perhaps this error has been
> fixed in later
> > versions.
> > Another problem might be that I have legacy functions installed in
> > the public schema and that they somehow conflict with postgis 2.0
> > being installed in the postgis schema. If this is the case, is it
> > possible to import those functions into the postgis schema
> as well (or
> > their own schema)?
> > Thanks
> > THX1138
> > View this message in context:
> http://postgis.17.n6.nabble.com/How-to-set-the-parent-schema-of-postgi
> > s-2-0-to-postgis-instead-of-public-tp4680493p4680493.html
> > Sent from the PostGIS - User mailing list archive at Nabble.com.
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Not sure, but, maybe you need to create it up front:
> CREATE extension postgis with SCHEMA postgis;
> -Andy
