[postgis-users] ERROR: Geometry has Z dimension but column does not
Gold, Jack L (US SSA)
jack.gold at baesystems.com
Thu Apr 5 11:27:11 PDT 2012
I'm beginning to think the problem is actually a corrupted database. I don't even have a geometry_columns table anymore. The SELECT Postgis_full_version() results in postgis_libjson_version() error shown below. I'm going to call it a corrupted database and rebuild from scratch. Thanks for the help Sandro.
ERROR: function postgis_libjson_version() does not exist
LINE 1: SELECT postgis_libjson_version()
HINT: No function matches the given name and argument types. You might need to add explicit type casts.
QUERY: SELECT postgis_libjson_version()
CONTEXT: PL/pgSQL function "postgis_full_version" line 20 at SQL statement
********** Error **********
SQL state: 42883
Hint: No function matches the given name and argument types. You might need to add explicit type casts.
Context: PL/pgSQL function "postgis_full_version" line 20 at SQL statement
--Jack
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Sandro Santilli
Sent: Thursday, April 05, 2012 2:15 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] ERROR: Geometry has Z dimension but column does not
On Thu, Apr 05, 2012 at 01:53:59PM -0400, Gold, Jack L (US SSA) wrote:
> My apologies, I sent the previous post in a hurry. Below is the query I am using to insert a geography from text. I still receive the error indicated. I am, in fact, looking to insert a geography with a Z value.
> CREATE TABLE myTable(location geography(PointZ,4326));
> INSERT INTO myTable (location) VALUES (st_geographyFromText('SRID=4326;PointZ(85 35 500)'));
Works for me. What's the result of : SELECT Postgis_full_version() ?
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
