[postgis-users] ERROR: Geometry has Z dimension but column does not
Sandro Santilli
strk at keybit.net
Fri Apr 6 00:29:26 PDT 2012
On Thu, Apr 05, 2012 at 11:17:40AM -0700, Paul Ramsey wrote:
> Working here. It's a problem with the st_geographyFromText somehow,
> you can insert values into the table if you feed it text directly.
> INSERT INTO myTable (location) VALUES ('SRID=4326;PointZ(85 35 500)');
Yep, that's what I was doing. Sorry for the false negative.
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
