[postgis-users] interpolate and extract points from line
Nicolas Ribot
nicolas.ribot at gmail.com
Sun Apr 8 04:26:23 PDT 2012
And even better: starting generate_series at 0 will give you the 245
points you're expecting:
select st_line_interpolate_point(
geom, generate_series(0, seg_fldr-1) * (1/(seg_fldr::float - 1))
) as geom
from smoothnav_line_wgs84;
On 8 April 2012 13:19, Nicolas Ribot <nicolas.ribot at gmail.com> wrote:
> Hi,
> Is st_segmentize() not enough to add points to your lines ?
> And are you sure you want to compute distance in decimal degrees ?
> there is the st_distanceSphere() function to compute distances on lat
> long data.
> Concerning the line interpolation, I think you are misusing the
> generate_series and st_line_interpolate_point functions:
> st_line_interpolate_point takes a fraction of total length, between 0
> and 1 (1 is the total length of your line).
> So you want to generate "seg_fldr" iterations, each representing 1 /
> (seg_fldr-1) fraction of the line:
> geom, generate_series(1, seg_fldr-1) * (1/(seg_fldr::float - 1))
> ) as geom
> It will generate seg_fldr-1 points spanning onto the line.
> Nicolas
> On 8 April 2012 09:34, Gery . <gamejihou at hotmail.com> wrote:
>> Hi,
>> This seems to be quite simple but I'm having a hard time trying to get what I want. The thing is that I have several lines and I'm trying to interpolate them and then extract the points to a CSV file for example. I'm still stuck in the interpolation step. This is what I have so far:
>> whole table:
>> mydb=# select id,profile,dist_dd,seg_fldr from smoothnav_line_wgs84 order by id;
>> id | profile | dist_dd | seg_fldr
>> 1 | 5148P-LF | 0.0010699943 | 245
>> 2 | 5745P-LF | 0.0015981060 | 282
>> 3 | 5920P-LF | 0.0012989445 | 295
>> 4 | 0053P-LF | 0.0013805557 | 304
>> 5 | 0233P-LF | 0.0012318259 | 278
>> 6 | 0416P-LF | 0.0012958645 | 287
>> 7 | 0601P-LF | 0.0011592394 | 227
>> 8 | 0729P-LF | 0.0013005116 | 328
>> 9 | 0946P-LF | 0.0012521930 | 239
>> 10 | 1119P-LF | 0.0013112367 | 300
>> 11 | 1258P-LF | 0.0013001241 | 254
>> 12 | 1434P-LF | 0.0012408036 | 269
>> 13 | 1622P-LF | 0.0010311844 | 225
>> 14 | 1800P-LF | 0.0009614843 | 229
>> 15 | 1927P-LF | 0.0011774532 | 247
>> 16 | 2103P-LF | 0.0011027050 | 243
>> 17 | 2236P-LF | 0.0011613916 | 231
>> 18 | 2410P-LF | 0.0010903102 | 254
>> 19 | 2546P-LF | 0.0011652277 | 227
>> 20 | 2722P-LF | 0.0010217751 | 246
>> 21 | 2903P-LF | 0.0010245117 | 225
>> 22 | 3056P-LF | 0.0011750912 | 283
>> 23 | 3240P-LF | 0.0010244741 | 209
>> 24 | 3403P-LF | 0.0012303394 | 302
>> 25 | 3550P-LF | 0.0011860473 | 246
>> 26 | 3733P-LF | 0.0013065220 | 299
>> 27 | 3922P-LF | 0.0011613916 | 232
>> 28 | 4213P-LF | 0.0027780243 | 588
>> 29 | 4517P-LF | 0.0027969726 | 629
>> 30 | 4831P-LF | 0.0028498347 | 571
>> 31 | 5146P-LF | 0.0029280876 | 633
>> 32 | 5459P-LF | 0.0028549158 | 551
>> 33 | 5823P-LF | 0.0028575039 | 597
>> 34 | 0124P-LF | 0.0029464684 | 616
>> 35 | 0436P-LF | 0.0029445455 | 609
>> 36 | 0808P-LF | 0.0029842086 | 592
>> (36 rows)
>> one row for tests:
>> mydb=# create table test1 as select * from smoothnav_line_wgs84 where id=1;
>> now, to generate points along the line in test1 I need the distance between points, so this is the dist_dd/(seg_fldr-1). In the id=1 above would be: 0.0010699943/(245-1) = 0.000004385222540983606557, so, I can get this like:
>> mydb=# select dist_dd/(seg_fldr-1) from test1 ;
>> ?column?
>> (1 row)
>> so far so good, here it comes the problem, I need to get 245 points from my line, this is starting from the actual origin and putting a point every 0.000004385222540983606557 decimal degrees, so at the end I should come up with 245 points instead of 49 points (because the current geom is actually composed of only 49 points), so I really think my command line doesn't reflect what I want, but it's what I'm trying to figure it out:
>> mydb=# select st_line_interpolate_point(geom,(dist_dd/(seg_fldr-1))), generate_series(1,max((seg_fldr)::int)) from test1;
>> and I'm getting this error: ERROR: column "test1.geom" must appear in the GROUP BY clause or be used in an aggregate function
>> I keep reading but perhaps this is too advanced to my sql understanding. Any help will be really appreciated.
>> Thanks,
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
