[postgis-users] Topology working example (was: Postgis topology help)
pcreso at pcreso.com
Sun Apr 8 14:55:14 PDT 2012
The attached script creates a Postgres database, adds Postgis with topology & uses linestring geometries as the underlying data to create topologies, then extracts the generated faces as simple polygon geometries.
It was a useful learning exercise for me to put this together, with advice from strk. I'm posting it here as I hope it will help others starting to use topologies with Postgis.
Cheers,
Brent Wood
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120408/2daca6f9/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120408/2daca6f9/attachment.obj>
