[postgis-users] Invalid SRID for geography type: ee4
Philippe
watcherfr at gmail.com
Tue Apr 10 13:50:19 PDT 2012
Hello,
I'm running into an issue loading data from the Belgium IGN.
I can transform a shapefile into Postgis loadable data with Geometry but
not Geography. I can't imagine why. Any ideas ? Thanks
The following works
/usr/lib/postgresql/9.1/bin/shp2pgsql -WLATIN1 -s3812 -d -I
/home/postgres/warehouse/shapes/BE/vector/Shape_L08/commune_polygon.shp
be_ign > /tmp/be_ign.sql
The following fails
/usr/lib/postgresql/9.1/bin/shp2pgsql -WLATIN1 -s3812 -G -d -I
with
"Shapefile type: Polygon
Postgis type: MULTIPOLYGON[2]
Invalid SRID for geography type: ee4"
Although 0xee4=3812 which is the EPSG for the Lambert 2008 projection used
by that file. And my spatial ref table contains it:
public=# select * from spatial_ref_sys where auth_srid=3812;
srid | 3812
auth_name | EPSG
auth_srid | 3812
srtext | PROJCS["ETRS89 / Belgian Lambert
2008",GEOGCS["ETRS89",DATUM["European_Terrestrial_Reference_System_1989",SPHEROID["GRS
1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6258"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4258"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],PROJECTION["Lambert_Conformal_Conic_2SP"],PARAMETER["standard_parallel_1",49.83333333333334],PARAMETER["standard_parallel_2",51.16666666666666],PARAMETER["latitude_of_origin",50.797815],PARAMETER["central_meridian",4.359215833333333],PARAMETER["false_easting",649328],PARAMETER["false_northing",665262],AUTHORITY["EPSG","3812"],AXIS["X",EAST],AXIS["Y",NORTH]]
proj4text | +proj=lcc +lat_1=49.83333333333334 +lat_2=51.16666666666666
+lat_0=50.797815 +lon_0=4.359215833333333 +x_0=649328 +y_0=665262
+ellps=GRS80 +units=m +no_defs
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120410/e351c4fc/attachment.html>
