[postgis-users] ST_Boundary(geometry) for polyon to line conversion?
Nicolas Ribot
nicolas.ribot at gmail.com
Wed Apr 11 00:49:55 PDT 2012
> Hi,
> Is this the function I would use to convert a polygon to a polyline?
> yours,
> Rob
Yes, but depends on the shape of the polygon. If it has holes,
st_boundary will return several linestring, for the exterior and for
each hole.
If you need only the exterior shape of the polygon, st_exteriorRing
may suit your needs better.
Nicolas
