[postgis-users] Simplifying a multipolygon layer, keeping polygon connection
Nicolas Ribot
nicolas.ribot at gmail.com
Wed Apr 11 04:40:01 PDT 2012
On 11 April 2012 11:23, Sandro Santilli <strk at keybit.net> wrote:
> On Wed, Apr 11, 2012 at 11:14:48AM +0200, Nicolas Ribot wrote:
>> Yes, here are some stats:
>> Mac OS X Snow Leopard, SSD drive, 8 gb ram
>> shared_buffers = 5120MB
>> work_mem = 1024MB
>> POSTGIS="2.0.0 r9605" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.7.1, 23
>> September 2009" GDAL="GDAL 1.8.0, released 2011/01/12" LIBXML="2.7.8"
>> TOPOLOGY RASTER
>> Number of objects in departement layer: 96 Num points 47036,
>> 1°) Using spatial functions:
>> First run: 8953.493 ms, second run: 8808.133 ms
>> 2°) Using Topology
>> First run: 13743 ms, second run: 14028 ms
>> (server stopped and restarted between runs.
> Which steps involved by the two methods ?
> I can see some steps are in common:
> 1: Loading of input
> 2: Linking of faces to attribute (area_orig/area_intersection)
> Could the first step be taken out and the second be
> profiled separately ?
Here are the tests I ran:
a working table is created from the initial departement table, by
dumping out the polygon:
create table expl_dep as (
select gid, code_dept, (st_dump(geom)).*
from departement
This table is then used as input.
___________________________
Method 1: using one SQL query:
select (st_dump(st_polygonize(distinct geom))).geom as geom
from (
select (st_dump(st_simplifyPreserveTopology(st_linemerge(st_union(geom)),
10000))).geom as geom
from (
select st_exteriorRing((st_dumpRings(geom)).geom) as geom
from expl_dep
) as foo
) as bar;
-- takes 6.1 to 6.4 seconds
Face linking:
select d.gid, d.code_dept, s.geom
from departement d, simple_dep s
where st_intersects(d.geom, s.geom)
and st_area(st_intersection(d.geom, s.geom))/st_area(s.geom) > 0.5;
-- takes 1.2 to 1.3 s
________________________________________
Method 2, using topology wrapped in a function:
(topo1 and topo2 are created outside the function):
create or replace function testSimplTopo() returns text as $$
select ST_CreateTopoGeo('topo1',ST_Collect(geom))
from expl_dep;
select ST_CreateTopoGeo('topo2', geom)
from (
select ST_Collect(st_simplifyPreserveTopology(geom, 10000)) as geom
from topo1.edge_data
) as foo;
$$ language sql;
-- takes 12.0 to 12.3 seconds.
Face linking:
with simple_face as (
select st_getFaceGeometry('topo2', face_id) as geom
from topo2.face
where face_id > 0
) select d.gid, d.code_dept, s.geom
from simple_face s, departement d
and st_area(st_intersection(s.geom, d.geom))/st_area(s.geom) > 0.5;
-- takes 1.2 to 1.3, like the other query
By the way, I tried to put calls to select dropTopology() into the
functions I wrote, but it fails.
Is it because it runs in the same transaction as the one that created the topo ?
Nicolas
