[postgis-users] Method to remove overlaps in a layer
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Wed Apr 11 11:40:22 PDT 2012
So I have been creating a very simple example based on the example in the toTopoGeom() documentation page:
http://www.postgis.org/documentation/manual-svn/toTopoGeom.html
SELECT CreateTopology('topo1',31467, 10);
CREATE TABLE ovlp.test02_topo (id integer);
SELECT AddTopoGeometryColumn('topo1', 'ovlp', 'test02_topo', 'topo', 'POLYGON');
INSERT INTO ovlp.test02_topo (id, topo)
SELECT id, topology.toTopoGeom(geom, 'topo1', 1)
FROM ovlp.test02
And I get:
********** Error **********
ERROR: interpolate_point4d: invalid F (1)
SQL state: XX000
Context: PL/pgSQL function "st_modedgesplit" line 94 at assignment
PL/pgSQL function "topogeo_addpoint" line 91 at assignment
PL/pgSQL function "topogeo_addlinestring" line 132 at assignment
SQL statement "SELECT array_cat(edges, array_agg(x)) FROM ( select topology.TopoGeo_addLinestring(atopology, rec.geom, tol) as x ) as foo"
PL/pgSQL function "topogeo_addpolygon" line 27 at assignment
SQL statement "INSERT INTO topo1.relation(topogeo_id, layer_id, element_type, element_id) SELECT 5, 1, 3, topogeo_addPolygon('topo1', '0103000020EB7A0000010000000800000000000080FD384B4100000000F461544100000000D84B4B41000000405069544100000000B55D4B41000000005C63544100000000BD594B4100000000965B544100000000C8694B41000000006255544100000080E15C4B4100000080474D544100000080ED404B41000000006C50544100000080FD384B4100000000F4615441'::geometry, 10);"
PL/pgSQL function "totopogeom" line 129 at EXECUTE statement
I join a picture of the original layer to be converted to a topologic layer.
I'm still at beta 5... Should upgrading solve that particular problem?
Pierre
> > So what would be the normal/easiest steps to convert a messy polygon
> coverage into a clean topology? Is it documented somewhere?
> > My guess:
> > 1- SET search_path TO topology,public;
> You shouldn't need this, when you load topology.sql you should
> get "topology" already appended to the end of the search_path
> associated with the database.
> > 2- SELECT CreateTopoGeom('test')
> Yep.
> > 3- SELECT toTopoGeom(geom, 'test', 1)
> > FROM mymessyone;
> You didn't create a layer, see AddTopoGeometryColumn.
> The third argument is a layer id, as returned by that function.
> > or
> > SELECT ST_CreateTopoGeo('test', geom)
> > FROM mymessyone;
> This one only works starting with an empty topology so
> you'll need to pass it a full collection:
> SELECT ST_CreateTopoGeo('test', ST_Collect(geom)) FROM mymessyone;
> But I'd recommend using toTopoGeom instead, to keep the linking
> between attributes and geometries.
> > What happens when a polygon to be added to the topology overlaps a
> polygon already in the topology?
> Two overlapping rectangles would produce a total of 3 faces.
> If you're returning TopoGeometry objects (your step 2) both
> of them will be defined by 2 faces, having one face in common.
Type: image/jpeg
Desc: overlaps.jpeg
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120411/91b42a72/attachment.jpeg>
