[postgis-users] Method to remove overlaps in a layer
Sandro Santilli
strk at keybit.net
Wed Apr 11 12:26:45 PDT 2012
On Wed, Apr 11, 2012 at 02:53:07PM -0400, Pierre Racine wrote:
> An even simpler example leads to another type of error:
> SELECT CreateTopology('topo3',0, 10);
> DROP TABLE IF EXISTS ovlp.test03;
> CREATE TABLE ovlp.test03 AS
> SELECT 1 id, ST_GeomFromText('POLYGON((0 1, 2 2, 2 0, 0 1))') geom
> UNION ALL
> SELECT 2 id, ST_GeomFromText('POLYGON((1 1, 3 2, 3 0, 1 1))') geom
> CREATE TABLE ovlp.test03_topo (id integer);
> SELECT AddTopoGeometryColumn('topo3', 'ovlp', 'test03_topo', 'topo', 'POLYGON'); -- 1
> INSERT INTO ovlp.test03_topo (id, topo)
> SELECT id, topology.toTopoGeom(geom, 'topo3', 1)
> FROM ovlp.test03
> gives:
> ********** Error **********
> ERROR: SQL/MM Spatial exception - edge crosses node.
Ouch, you're lucky. It kills the backend here !!
I'm on it.
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
