[postgis-users] Problem installing 2.0 from RPM
Thom DeCarlo
pixelpshr at gmail.com
Thu Apr 12 08:58:35 PDT 2012
I'm trying to install the new release from the RPMs found on the PostgreSQL
website and having trouble with missing dependencies.
The particulars:
Installing on RHEL 6 x86_64
I've set up my yum.conf and rhnplugin.conf as directed on
http://wiki.postgresql.org/wiki/YUM_Installation
and i can get the list using
yum list postgis2_91*
however, when trying to install, it gets as far as checking the
dependencies for gdal and starts giving error messages. Where should I be
looking to resolve these dependencies?
$ sudo yum install postgis2_91
Loaded plugins: product-id, refresh-packagekit, rhnplugin,
subscription-manager
Updating certificate-based repositories.
Setting up Install Process
Resolving Dependencies
--> Running transaction check
---> Package postgis2_91.x86_64 0:2.0.0-1.rhel6 will be installed
--> Processing Dependency: proj for package:
postgis2_91-2.0.0-1.rhel6.x86_64
--> Processing Dependency: geos for package:
--> Processing Dependency: libgeos_c.so.1()(64bit) for package:
--> Processing Dependency: libgdal.so.1()(64bit) for package:
--> Processing Dependency: libproj.so.0()(64bit) for package:
---> Package gdal.x86_64 0:1.7.2-1.el6 will be installed
--> Processing Dependency: libdapclient.so.3()(64bit) for package:
gdal-1.7.2-1.el6.x86_64
--> Processing Dependency: librx.so.0()(64bit) for package:
--> Processing Dependency: libogdi.so.3()(64bit) for package:
--> Processing Dependency: libgeotiff.so.1.2()(64bit) for package:
--> Processing Dependency: libdap.so.11()(64bit) for package:
--> Processing Dependency: libxerces-c-3.0.so()(64bit) for package:
--> Processing Dependency: libcfitsio.so.0()(64bit) for package:
--> Processing Dependency: libdapserver.so.7()(64bit) for package:
--> Processing Dependency: libhdf5.so.6()(64bit) for package:
--> Processing Dependency: libnetcdf.so.6()(64bit) for package:
---> Package geos.x86_64 0:3.3.3-1.rhel6 will be installed
---> Package proj.x86_64 0:4.7.0-1.rhel6 will be installed
--> Finished Dependency Resolution
Error: Package: gdal-1.7.2-1.el6.x86_64 (pgdg91)
Requires: libgeotiff.so.1.2()(64bit)
Requires: libdap.so.11()(64bit)
Requires: libnetcdf.so.6()(64bit)
Requires: libxerces-c-3.0.so()(64bit)
Requires: libdapclient.so.3()(64bit)
Requires: libogdi.so.3()(64bit)
Requires: librx.so.0()(64bit)
Requires: libhdf5.so.6()(64bit)
Requires: libdapserver.so.7()(64bit)
Requires: libcfitsio.so.0()(64bit)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120412/93c3ebdd/attachment.html>
