I don't think raster2pgsql can be use to reproject anything : it could be better to import the raster into postgis using its original projection and then use postgis to reproject to the wanted srid using st_transform
(http://www.postgis.org/documentation/manual-svn/RT_ST_Transform.html)
Hug
-------- Message d'origine--------
De: postgis-users-bounces at postgis.refractions.net de la part de Mark Wynter
Date: sam. 14/04/2012 08:37
À: postgis-users at postgis.refractions.net
Objet : [postgis-users] raster2psql - reprojection issue
This may be a basic issue, but I'm on a steep learning curve with respect to raster analysis and PostGIS 2.0.
I have a large land use raster file ( w001001.adf ) projected in EPSG:3577 - GDA94 / Australian Albers. In QGIS when opening this file, I can do an "on the fly" CRS transformation to SRID 4326 and all is good.
When importing this file into PostGIS, is it possible to transform this file into a geographic coordinate system, and if so, how?
I've loaded the data into PostGIS using: raster2pgsql -s 4326 -I -C -M w001001.adf -F -t 5000x5000 landuse_50m | psql -U postgres -d test
However, when I then view the resultant PostGIS table in OPENJUMP, the data remains in the projected coordinate system rather than the geographic coordinate system. i.e. upper left = -1888000.000,-1010000.000, not decimal degrees.
Details of w001001.adf are as follows:
gdalinfo w001001.adf file
Driver: AIG/Arc/Info Binary Grid
Size is 80200, 76740
Coordinate System is:
PROJCS["unnamed",
GEOGCS["GDA94",
DATUM["Geocentric_Datum_of_Australia_1994",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6283"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4283"]],
PROJECTION["Albers_Conic_Equal_Area"],
PARAMETER["standard_parallel_1",-18],
PARAMETER["standard_parallel_2",-36],
PARAMETER["latitude_of_center",0],
PARAMETER["longitude_of_center",132],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["METERS",1]]
Origin = (-1888000.000000000000000,-1010000.000000000000000)
Pixel Size = (50.000000000000000,-50.000000000000000)
Corner Coordinates:
Upper Left (-1888000.000,-1010000.000) (115d23'34.35"E, 8d29'49.17"S)
Lower Left (-1888000.000,-4847000.000) (109d29'30.81"E, 42d49'11.28"S)
Upper Right ( 2122000.000,-1010000.000) (150d38'16.50"E, 8d11'43.92"S)
Lower Right ( 2122000.000,-4847000.000) (157d13'46.69"E, 42d25' 0.67"S)
Center ( 117000.000,-2928500.000) (133d11'36.60"E, 27d 0'36.35"S)
Band 1 Block=256x4 Type=Int16, ColorInterp=Undefined
Min=100.000 Max=663.000
NoData Value=-32768
Is there something I'm not doing, or understanding? Could someone please help me out?
Kind regards, Mark
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120414/a1acb0a4/attachment.bin>
