[postgis-users] ST_MakeValid
Stephen V. Mather
svm at clevelandmetroparks.com
Mon Apr 16 09:35:50 PDT 2012
Credit where credit is due-the cleanGeometry function listed below is
written by Horst Duester.
Best,
Steve
http://www.clemetparks.com/images/esig/cmp-ms-90x122.pngStephen Mather
Geographic Information Systems (GIS) Manager
(216) 635-3243
<http://www.clemetparks.com/> clevelandmetroparks.com
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
V. Mather
Sent: Monday, April 16, 2012 12:33 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] ST_MakeValid
Hi All,
Has anyone done any performance tests on ST_MakeValid? I
had been using Tim Sutton's cleanGeometry function from circa 2010
(http://linfiniti.com/2010/07/cleaning-geometries-inside-postgis/) to clean
up geometries. Works most of the time-every now and then I throw it
something too big and harry and it runs for weeks and weeks and never (AFAI
have the patience for) completes. I've been looking forward to
ST_MakeValid.
Today, a new Postgis 2.0 instance in hand, I was playing
with a dataset with 9106 invalid geometries-all self intersecting geometries
from raster-->vector conversion in an un-named proprietary package. On a
whim, I decided to compare the speed of ST_MakeValid to Tim's code, so first
I needed the correct functions:
psql -U postgres -d test -f "C:\Program
Files\PostgreSQL\9.1\share\contrib\postgis-2.0\legacy.sql"
Then a quick run through cleanGeometry:
CREATE TABLE tpi_clean AS
SELECT gid, id, gridcode, "class name", cleanGeometry(geom)
FROM tpi;
And I get back:
Query returned successfully: 1004952 rows affected, 955444 ms execution
time.
If I run as ST_MakeValid,
CREATE TABLE tpi_valid AS
SELECT gid, id, gridcode, "class name", ST_MakeValid(geom)
FROM tpi;
At 2300000 milliseconds, it is still running. .
This is PostgreSQL 9.1, PostGIS 2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1, on
Windows XP 32-bit. I have not yet tested on my Ubuntu box. .
Thanks,
Best,
Steve
(216) 635-3243
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120416/ce16a053/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120416/ce16a053/attachment.png>
