[postgis-users] ST_MakeValid
Stephen V. Mather
svm at clevelandmetroparks.com
Mon Apr 16 12:02:13 PDT 2012
Forgot to reply all...
> The ST_MakeValid tries its best to retain all input vertices.
AFAIK, Horst's function does as well.
> Also, ST_MakeValid internally checks for input validity and avoids
> running anything if the input is valid. Such check has a cost too.
Horst's function naturally leverages the old "isValid".
I'm going to try on one of the datasets that Horst's function fails on, as I
suspect the new native function is less likely to fail. I'll take stability
over speed (most of the time, anyway...).
FYI, an excerpt from the code from Horst's function
http://www.sogis1.so.ch/sogis/dl/postgis/cleanGeometry.sql
Does the following for the polygon case:
IF (GeometryType(inGeom) = 'POLYGON' OR GeometryType(inGeom) =
'MULTIPOLYGON') THEN
-- Only process if geometry is not valid,
-- otherwise put out without change
if not isValid(inGeom) THEN
-- create nodes at all self-intersecting lines by union the polygon
boundaries
-- with the startingpoint of the boundary.
tmpLinestring :=
st_union(st_multi(st_boundary(inGeom)),st_pointn(boundary(inGeom),1));
outGeom = buildarea(tmpLinestring);
IF (GeometryType(inGeom) = 'MULTIPOLYGON') THEN
RETURN st_multi(outGeom);
ELSE
RETURN outGeom;
END IF;
else
RETURN inGeom;
END IF;
Best,
Steve
Stephen Mather
Geographic Information Systems (GIS) Manager
(216) 635-3243
-----Original Message-----
From: Sandro Santilli [mailto:sandro.santilli at gmail.com] On Behalf Of Sandro
Santilli
Sent: Monday, April 16, 2012 12:41 PM
To: svm at clevelandmetroparks.com; PostGIS Users Discussion
Subject: Re: [postgis-users] ST_MakeValid
On Mon, Apr 16, 2012 at 12:33:15PM -0400, Stephen V. Mather wrote:
> Then a quick run through cleanGeometry:
> Query returned successfully: 1004952 rows affected, 955444 ms execution
time.
> If I run as ST_MakeValid,
> At 2300000 milliseconds, it is still running. .
IIRC there's a difference with a multipolygon composed by two
overlapping rectangles.
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
