[postgis-users] Use of tolerances in topology
Jose Carlos Martinez
jomarlla at cgf.upv.es
Tue Apr 17 10:03:00 PDT 2012
Thanks Paul, hope you can find the time to make it, for sure it would be
outstanding.
On 17/04/2012 18:58, Paul Ramsey wrote:
> Your understanding is correct, the approach is mostly brute force, and
> I have a pile of code lying about waiting to go in that implements
> what you describe in terms of building internal indexes.
> P.
> On Tue, Apr 17, 2012 at 9:29 AM, Jose Carlos Martinez
> <jomarlla at cgf.upv.es> wrote:
>> Thanks Sandro, I understand now.
>> About trying to enhance ST_Dwithin, last time I checked PostGIS code it was
>> implemented using brute force (after comparing the boxes). Maybe one way to
>> improve the algorithm (DT_Dwithin) will be to use spatial indexes inside a
>> geometry. According to my tests (long time ago with JTS) I remember it could
>> be faster to build a spatial index every time for a geometry and use it than
>> using brute force (with geometries with more than 20 vertexes or so).
>> Anyways Im not sure if PostGIS is still using brute force with st_dwithin,
>> if so then forget everything I said.
>> Regards,
>> On 17/04/2012 17:46, Sandro Santilli wrote:
>>> On Tue, Apr 17, 2012 at 05:35:42PM +0200, Jose Carlos Martinez wrote:
>>>> Hi Sandro, Im learning from topology.sql how the topology functions
>>>> are working with more detail.
>>>> I have a question about how the tolerances are managed, for example:
>>>> I see (ST_AddIsoEdge) that you have used some times spatial
>>>> predicates as st_contains or st_intersects. As you know these
>>>> predicates (and others too) just work in a good way if the
>>>> geometries are snapped to each other previously, so my question is
>>>> why you didnt use st_Dwithin with a tolerance? or maybe these
>>>> functions expect the geometries to be already snapped by totopogeom
>>>> for example and they shouldnt be used directly?
>>> Those functions are ISO functions and as such are not specified to
>>> deal with a tolerance. Handling of tolerance is not always
>>> straightforward as using ST_DWithin. It may also have a big cost.
>>> So take all those functions as being expected to be already snapped.
>>> I'm open to suggestion about enhanced versions taking tolerance into
>>> consideration. But it must be possible to invoke such functions in
>>> a fast way, when caller already did their checking and noding and what
>>> not.
>>> The idea is that all the ST_ prefixed functions end up being just wrappers
>>> around more flexible functions in core.
>>> --strk;
>>> ,------o-.
>>> | __/ | Delivering high quality PostGIS 2.0 !
>>> | / 2.0 | http://strk.keybit.net - http://vizzuality.com
>>> `-o------'
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
