[postgis-users] intersects (topogeom, topogeom) is too slow
Jose Carlos Martinez Llario
jomarlla at cgf.upv.es
Tue Apr 17 14:47:18 PDT 2012
On 17/04/2012 23:42, Andy Colson wrote:
> On 4/17/2012 4:36 PM, Andy Colson wrote:
>> On 4/17/2012 4:00 PM, Jose Carlos Martinez Llario wrote:
>>> Hi,
>>> first I wanted to say thanks because Im asking a lot of questions
>>> lately
>>> and you guys always answer me in a fast and kind way. Sandro you
>>> specially must be tired of me. sorry!! :)
>>> now another more question.
>>> I found the function intersects (topogeom, topogeom) quite interesting
>>> even it is not documented, because I was expecting it to show me the
>>> persistent topology performance.
>>> I have a table called suelos (10000 polygons) with a normal geometry
>>> column (geom) and a topology column (topogeom) where I populated the
>>> geometries.
>>> This query takes 25 secs.
>>> select count(*) from suelos s1, suelos s2 where st_intersects (s1.geom,
>>> s2.geom);
>>> I was expecting this query to take 1 or less secs:
>>> select count(*) from suelos s1, suelos s2 where intersects
>>> (s1.topogeom,
>>> s2.topogeom);
>>> but after taking more than 10 mins I cancelled it.
>>> Then I noticed that the topogeom column is not using any spatial index
>>> then I added a column:
>>> s1=# alter table suelos add column box geometry (polygon, 23030);
>>> s1=# update suelos set box = st_envelope (topogeom::geometry);
>>> s1=# create index gist_suelos_topogeom using gist (box);
>>> and the following sentence took 60 secs (still much more that I was
>>> expecting)
>>> select count(*) from suelos s1, suelos s2 where s1.box && s2.box and
>>> intersects (s1.topogeom, s2.topogeom);
>>> Then my questions?
>>> - How can we use spatial index with topogeometry layers, making a new
>>> box column and keep it synchronized? Why topogeom composite type does
>>> not include a box that we can index?
>>> - The topogeom composite type is using indexes with its fields?
>>> - Why its taking more time that geometry types if it should have
>>> opposite behavior?
>>> Regards and thanks,
>>> Jose
>> Have you tried something like:
>> where intersects (s1.topogeom, st_envelope(s2.topogeom));
>> You can put an update trigger on the table to reset the box.
>> -Andy
> Oops. Forget this part, it makes no sense at all, sorry.
> >> expecting)
> You are comparing every row of one table to every row of the other.
> That is probably not a real world query, is it? Wont you have some
> other conditions you can put on? A bounding box to draw? A click
> point? How real world is this query?
Its not related with that. it makes sense. You can check
self-intersections, self-overlaping in one layer or any other issue.
With two different layers the same problem remains.
> -Andy
> postgis-users mailing list
