[postgis-users] configure error: could not find gdal
Simon Ortet simon.ortet at gmail.com
Wed Apr 18 02:39:43 PDT 2012
Thanks Mike I could solve it with your help:
I've checked my postgis config.log and found this:
/usr/bin/ld: warning: libpq.so.5, needed by /usr/local/lib/libgdal.so, not
found (try using -rpath or -rpath-link)
I had installed postgres 9.1.3 from sources in /usr/local/pgsql and the
symlinks libpq.so.* are in /usr/local/pgsql/lib
So I added that directory to ld.so.conf, run ldconfig and the ./configure
of postgis passed.
It's odd I never had to do that in my previous postgres installs. I'll keep
that in mind from now on.
Thanks a lot for your help.
Simon
2012/4/18 Mike Toews <mwtoews at gmail.com>
> Here is one of the issues with GDALAllRegister:
> http://postgis.refractions.net/pipermail/postgis-users/2012-March/033043.html
> Do you remember the details of building GDAL? What version of GEOS do
> you have, and did you also install it from source for GDAL?
> $ geos-config --prefix
> $ geos-config --version
> -Mike
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120418/4b9928e4/attachment.html>
