[postgis-users] GDALFPolygonize undefined in rtpostgis-2.0
Gold, Jack L (US SSA) jack.gold at baesystems.com
Thu Apr 19 14:33:41 PDT 2012
BBorie,
The config.log indicates "result: none required".  I know this is for the ac_cv_search, but does that have any effect on the symbol being compiled in?  I searched my system for alternate gdal installs and found none.
--Jack
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bborie Park
Sent: Thursday, April 19, 2012 5:10 PM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] GDALFPolygonize undefined in rtpostgis-2.0
Jack,
My guess is that there are more than one GDAL libraries on your system and the GDAL library used for testing the presence of GDAFPolygonize is different than the GDAL library attempting to be loaded.  Since you built postgis from source, you should be able to check config.log and inspect the lines regarding the GDALFPolygonize test.
-bborie
On 04/19/2012 02:02 PM, Gold, Jack L (US SSA) wrote:
> I am building and installing PostGIS 2.0.1SVN.  Whenever I attempt to load rtpostgis.sql I receive the following error:
> ERROR:  could not load library "/usr/local/pgsql/lib/rtpostgis-2.0":
> /usr/local/pgsql/lib/rtpostgis-2.0: undefined symbol: GDALFPolygonize
> ********** Error **********
> SQL state: XX000
> I built and installed postgresql-9.1.3 (--with-python),  proj-4.8.0 (--without-jni), geos-3.3.2 (--enable-python), and gdal-1.9.0 (--with-python --with-java=/opt/jdk1.6.0_26 --with-geos=../geos-3.3.2/tools/geos-config).
> Finally, I built PostGIS-2.0.1SVN --with-raster -with-pgconfig=/usr/local/pgsql/bin/pg_config -with-geosconfig=../geos-3.3.2/tools/geos-config.
> /etc/ld.so.conf.d contains postgresql.conf:
> /usr/local/lib
> /usr/lib
> All libraries are stored in one of these locations.
> $nm -u /usr/local/pgsql/lib/rtpostgis-2.0 | grep GDALFPolygonize U
> GDALFPolygonize
> $ nm --dynamic /usr/local/lib/libgdal.so.1.16.0 | grep GDALFPolygonize
> 004b4a40 T GDALFPolygonize
> Any idea why the symbol is undefined in rtpostgis-2.0?
> --Jack Gold
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
bkpark at ucdavis.edu
