[postgis-users] compiling documentation
Salvatore Larosa lrssvtml at gmail.com
Mon Apr 23 14:29:32 PDT 2012
Il giorno lun, 23/04/2012 alle 23.08 +0200, Pasquale Di Donato ha
scritto:
> There is no config file
configure file is found in root folder!
If it is not there, you need run autogen.sh before
In order to compile doc you must before run ./configure to create
"Makefile" and then run "make html" to build!
