[postgis-users] banging my head on setting up and running geodjango
Nabil Servais
nabil.servais at gmail.com
Tue Apr 24 10:10:48 PDT 2012
Could you post your settings.py please? I think it's a problem with the
database section.
Le 24 avr. 2012 19:03, "Smaran Harihar" <smaran.harihar at gmail.com> a écrit :
> Hi,
> I am really fed up in setting up and running GeoDjango.
> The first step was to setup the Spatial Database in PostGIS which I was
> really banging my head when it came to OS X. So i shifted to Ubuntu 11.10
> and it seemed it was quite easy. Now having completed the post
> installation process<https://docs.djangoproject.com/en/dev/ref/contrib/gis/install/#creating-a-spatial-database-template-for-postgis>,
> I created the required changes that need to be done in the settings.py and
> now i am trying to,
> python manage.py sqlall world
> but it is returning a bunch of errors.
> (django-env)smaranh at ubuntu:~/geodjango$ python manage.py sqlall world
> Traceback (most recent call last):
> File "manage.py", line 10, in <module>
> execute_from_command_line(sys.argv)
> File
> "/home/smaranh/django-env/local/lib/python2.7/site-packages/django/core/management/__init__.py",
> line 443, in execute_from_command_line
> utility.execute()
> File
> line 382, in execute
> self.fetch_command(subcommand).run_from_argv(self.argv)
> File
> line 261, in fetch_command
> klass = load_command_class(app_name, subcommand)
> File
> line 69, in load_command_class
> module = import_module('%s.management.commands.%s' % (app_name, name))
> File
> "/home/smaranh/django-env/local/lib/python2.7/site-packages/django/utils/importlib.py",
> line 35, in import_module
> __import__(name)
> File
> "/home/smaranh/django-env/local/lib/python2.7/site-packages/django/core/management/commands/sqlall.py",
> line 4, in <module>
> from django.core.management.sql import sql_all
> File
> "/home/smaranh/django-env/local/lib/python2.7/site-packages/django/core/management/sql.py",
> line 6, in <module>
> from django.db import models
> File
> "/home/smaranh/django-env/local/lib/python2.7/site-packages/django/db/__init__.py",
> line 40, in <module>
> backend = load_backend(connection.settings_dict['ENGINE'])
> File
> line 34, in __getattr__
> return getattr(connections[DEFAULT_DB_ALIAS], item)
> File
> "/home/smaranh/django-env/local/lib/python2.7/site-packages/django/db/utils.py",
> line 92, in __getitem__
> backend = load_backend(db['ENGINE'])
> File
> line 44, in load_backend
> raise ImproperlyConfigured(error_msg)
> django.core.exceptions.ImproperlyConfigured:
> 'django.contrib.gis.db.backends.postgis' isn't an available database
> backend.
> Try using django.db.backends.XXX, where XXX is one of:
> 'dummy', 'mysql', 'oracle', 'postgresql_psycopg2', 'sqlite3'
> Error was: No module named psycopg2.extensions
> Really need your help guys.
> Thanks & Regards
> Smaran Harihar
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120424/5840ee76/attachment.html>
