[postgis-users] Topology
Bob Pawley
rjpawley at shaw.ca
Tue Apr 24 10:14:52 PDT 2012
Hi
I’ve set up postgis 2.0 and have run the topology.sql file.
Select postgis_full_version() returns the TOPOLOGY label.
However, unlike the postgis 1.5 setup, when I run
select topology.CreateTopology('TEST', -1);
I get the following error which I’m not able to interpret.
NOTICE: CREATE TABLE will create implicit sequence "face_face_id_seq" for serial column "face.face_id"
CONTEXT: SQL statement "CREATE TABLE "TEST".face (face_id SERIAL, CONSTRAINT face_primary_key PRIMARY KEY(face_id));"
PL/pgSQL function "createtopology" line 26 at EXECUTE statement
NOTICE: CREATE TABLE / PRIMARY KEY will create implicit index "face_primary_key" for table "face"
ERROR: function addgeometrycolumn(unknown, unknown, unknown, unknown, unknown, integer) is not unique
LINE 1: SELECT AddGeometryColumn('TEST','face','mbr','-1','POLYGON',...
HINT: Could not choose a best candidate function. You might need to add explicit type casts.
QUERY: SELECT AddGeometryColumn('TEST','face','mbr','-1','POLYGON',2)
CONTEXT: PL/pgSQL function "createtopology" line 33 at EXECUTE statement
Any help would be appreciated.
Bob
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120424/2fe03f1e/attachment.html>
