[postgis-users] Installation Error
Smaran Harihar
smaran.harihar at gmail.com
Tue Apr 24 10:32:41 PDT 2012
I tried installing GeoDjango on Ubuntu and assumed that GEOS and Proj
existed on Linux and directly installed PostGIS.
Now I ran the tests as given on the Django
site<https://code.djangoproject.com/wiki/GeoDjangoInstall#Third-PartyLibraryInstallationTests>,
and this is the output I am receiving
>>>from django.contrib.gis.tests import test_gdal
File "<stdin>", line 1, in <module>
File
"/home/smaranh/django-env/local/lib/python2.7/site-packages/django/contrib/gis/tests/__init__.py",
line 2, in <module>
from django.test.simple import build_suite, DjangoTestSuiteRunner
File
"/home/smaranh/django-env/local/lib/python2.7/site-packages/django/test/__init__.py",
line 5, in <module>
from django.test.client import Client, RequestFactory
File
"/home/smaranh/django-env/local/lib/python2.7/site-packages/django/test/client.py",
line 21, in <module>
from django.test import signals
File
"/home/smaranh/django-env/local/lib/python2.7/site-packages/django/test/signals.py",
line 2, in <module>
from django.db import connections
File
"/home/smaranh/django-env/local/lib/python2.7/site-packages/django/db/__init__.py",
line 11, in <module>
if DEFAULT_DB_ALIAS not in settings.DATABASES:
File
"/home/smaranh/django-env/local/lib/python2.7/site-packages/django/utils/functional.py",
line 184, in inner
self._setup()
File
"/home/smaranh/django-env/local/lib/python2.7/site-packages/django/conf/__init__.py",
line 40, in _setup
raise ImportError("Settings cannot be imported, because environment
variable %s is undefined." % ENVIRONMENT_VARIABLE)
ImportError: Settings cannot be imported, because environment variable
DJANGO_SETTINGS_MODULE is undefined.
Should I uninstall PostGIS and install GEOS and PROJ or should I install
them over PostGIS? Also how do I uninstall PostGIS?
Thanks & Regards
Smaran Harihar
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120424/21769044/attachment.html>
