[postgis-users] Geom/Rast Intersection St9bad_alloc
JamesH
james.holmes at newcastle.ac.uk
Tue Apr 24 12:31:15 PDT 2012
"What is the type of the geometries you are intersecting with the raster?"
I am intersecting a shapefile of polygons.
-If they are polygons, what proportion of your raster does all your geometry
layer represent?
They do cover a large proportion of the raster.
ST_SummaryStatsAgg is not installed with PostGIS 2.0. You will find here:
http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/st_summarystatsagg.sql
I copied the code and ran it, returned as successful but when I run the full
query it says that function ST_SummaryStatsagg(raster) does not exist.
Have I copied the function incorrect>
Thank you for your reply,
Regards,
James
GIS Undergraduate
View this message in context: http://postgis.17.n6.nabble.com/Geom-Rast-Intersection-St9bad-alloc-tp4912994p4914495.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
