[postgis-users] Using shp2pgsql
Stephen V. Mather svm at clevelandmetroparks.com
Wed Apr 25 09:07:06 PDT 2012
I think he means run it in psql so that you can observe what line the error
occurs.  You are unlikely to see the error before loading it in psql.
Best,
Steve
http://www.clemetparks.com/images/esig/cmp-ms-90x122.pngStephen Mather
Geographic Information Systems (GIS) Manager
(216) 635-3243
 <http://www.clemetparks.com/> clevelandmetroparks.com
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Maddock
Sent: Wednesday, April 25, 2012 11:02 AM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] Using shp2pgsql
Nothing, the sql file looks beautiful.  No errors.  The interesting thing to
me is that it repeats the error when I pipe it and the error repeats for as
many time as there are rows of data.
What could this mean?  Might there be something wrong with my schema?
Shp2psql is supposed to create the table which it does:
SET CLIENT_ENCODING TO UTF8;
SET STANDARD_CONFORMING_STRINGS TO ON;
BEGIN;
CREATE TABLE "columbus"."pole_region" (gid serial PRIMARY KEY,
"location_n" varchar(15),
"height" float8,
"class" varchar(11),
"ownership" varchar(7),
"owner" varchar(80),
"plant_acct" varchar(31),
"vintage_ye" float8,
"inservice_" varchar(12),
"pole_kind" varchar(31),
"pole_type" varchar(24),
"original_t" varchar(25),
"design_sta" varchar(18),
"facility_s" varchar(10),
"ciac_statu" varchar(8),
"ciac_date" varchar(12),
"west_pole_" varchar(6));
SELECT
AddGeometryColumn('columbus','pole_region','geom_3754','3754','MULTIPOLYGON'
,4);
From: Denis Rouzaud [mailto:denis.rouzaud at gmail.com]
Sent: Wednesday, April 25, 2012 10:52 AM
To: PostGIS Users Discussion
Cc: Paul Maddock
You could output shp2pgsql to a SQL file, then use it in psql to see at
which line the error occurs.
On 04/25/2012 04:46 PM, Paul Maddock wrote:
Dear all,
I'm using the following code to transform a shapefile I have into a table
and import it into my database:
shp2pgsql -s 3754 ~/JOE/columbus/pole_region.shp columbus.pole_region | psql
-h localhost -U postgres -p 5432 -d paul
When it runs I have to put my password in for postgres (expected), and I get
the following output:
ERROR:  current transaction is aborted, commands ignored until end of
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
The database paul is created and the schema columbus is created and is owned
by postgres.
What am I doing wrong?  Do I have to set datatypes?
Thanks for the help,
Paul
Paul A. Maddock
Mapping Technician
IJUS LLC
560 Officenter Place
Gahanna, OH 43230
Cell: (513) 404-6476
 <http://www.ijus.net/index.html> Description: Description: Home
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120425/d6de0bb3/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120425/d6de0bb3/attachment.png>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120425/d6de0bb3/attachment.gif>
