[postgis-users] Simple Point Density Surface
Doug_Newcomb at fws.gov
Wed Apr 25 12:53:07 PDT 2012
>Thanks for the reference Doug. What you suggest does sound like it could
>work, the only thing is that
>I would need to have this output as a Raster as I am then looking to use
it
>with two other rasters
>to do a weighted combination of them e.g. [rast1 * 0.2] + [rast2 * 0.5] +
?[rast3 * 0.3].
>Do you know how if I could easily rasterise the output of what you've
>suggested?
James,
Unfortunately, I have not waded into rasters inside postgis yet. I'm
speculating that you could generate a raster from the point values you
generated from the suggested calculation. ( Using St_AsRaster,
http://postgis.refractions.net/docs/RT_ST_AsRaster.html ?)
For raster algebra, I usually use GRASS r.mapcalculator -
http://grass.fbk.eu/gdp/html_grass64/r.mapcalculator.html. If you can
dump your images out to files, you could import them to grass ( or use
r.external to link to them) and perform the calculation you described. If
you want to stay in postgis, just do the calculation in two steps.
>Only reason is I'm working on it for a dissertation project and I've left
>myself little time left to consider this.
Sounds like my grad school experience :-)
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of the
Interior. Life is too short for undocumented, proprietary data formats.
JamesH <james.holmes at newcastle.ac.uk>
Sent by: postgis-users-bounces at postgis.refractions.net
04/25/2012 02:49 PM
Please respond to
PostGIS Users Discussion <postgis-users at postgis.refractions.net>
To
cc
Subject
Re: [postgis-users] Simple Point Density Surface
"Why not convert the raster cell centers to points , do a query on the
point layer for a square centered on the raster derived point whose
dimensions are given by the number of tiles in your neighborhood. return
the number of points divided by the area of the square. ( neighborhoods
are usually odd numbers of cells, 3x3, 5x5, etc so you have an equal
number around the center cell)"
it
[rast3 * 0.3].
suggested?
Kind Regards,
James
GIS Undergraduate
View this message in context:
http://postgis.17.n6.nabble.com/Simple-Point-Density-Surface-tp4917343p4917632.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120425/fdc9ef2d/attachment.html>
