[postgis-users] Using PosGIS in one dimension
Alvaro Tejero Cantero
alvaro at minin.es
Wed Apr 25 14:54:40 PDT 2012
David, Mike,
thank you very much for this spot-on information!
I have two follow-up questions:
1/ is there an estimated release date for pg 9.2? (in its stead: are
Postgres pre-release versions usually 'stable enough' - I am in an
explorative setting, rock-solid stability is not yet needed).
2/ do these functions work with sets of intervals? I found an older post
about an extension that seems to care for that
http://scottrbailey.wordpress.com/2009/10/06/timespan_sets/
and I am concerned about how to do that efficiently (i.e. without a double
loop on A intervals and B intervals).
Thanks again,
-á.
On Wed, Apr 25, 2012 at 22:43, Mike Toews <mwtoews at gmail.com> wrote:
> On 26 April 2012 07:41, David William Bitner <bitner at gyttja.org> wrote:
> > If you follow PostgreSQL development, you can see that 9.2 is bringing a
> > whole suite of range data types for dealing with one dimensional
> intervals
> > with the same expressivity as PostGIS. Not there yet, but coming soon....
> Yup, I'll certainly agree with David's suggestion of the new range
> type for 9.2. You can define integer ranges using int4range. The range
> type shares some of the same DB technology as PostGIS, such as GiST
> indices, so it is sort-of a 1D version of PostGIS.
> A really good article describing the upcoming range type is at:
> http://www.depesz.com/2011/11/07/waiting-for-9-2-range-data-types/
> -Mike
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120425/2eab1d7b/attachment.html>
