[postgis-users] Problems after update to PostGis 2.0
Sandro Santilli
strk at keybit.net
Thu Apr 26 02:20:27 PDT 2012
On Thu, Apr 26, 2012 at 09:44:01AM +0200, Felix Obermaier wrote:
> Unfortunatly the geometry part of the database was not recoverable.
> All types of backup failed because geometry columns could not be included.
Did you try re-installing postgis 1.5.x ?
> Here is what I did:
> - I had a database with postgis 1.5.2 installed, tried to run postgis_upgrade_20_minor.sql which failed.
Excellent. It should even fail with a clear message about why
it was wrong to try that and what to do instead (did it?).
> - Updated that database to postgis 1.5.3, which succeeded.
Good. How did you do that ?
> - Re ran postgis_upgrade_20_minor.sql, which this time succeeded.
Ouch. This shouldn't have happened.
Could you please file a ticket for this ?
> IMHO the Installation/Upgrade documentation does not explicitly state
> that you have to do a backup/restore to update from postgis 1.5 or prior.
It's in the README file, under the section UPGRADING:
<< PostGIS provides a SOFT UPGRADE procedure for minor or bugfix releases,
and an HARD UPGRADE procedure for major releases. >>
Maybe it isn't clear how to distinguish a "minor or bugfix" release
from a "major" release ?
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
