[postgis-users] Problems after update to PostGis 2.0
Sandro Santilli
strk at keybit.net
Thu Apr 26 07:17:18 PDT 2012
On Thu, Apr 26, 2012 at 11:39:55AM +0200, Felix Obermaier wrote:
> > Did you try re-installing postgis 1.5.x ?
> Yes, I did, but it complained that this or that function could not be dropped/replaced because objects were depending on it.
Not with postgis_upgrade_15_minor I guess ?
> I finally tweaked the uninstall_postgis.sql script to DROP CASCADE but then all geometry columns were gone :(.
Ouch. Wrong move.
> It is not really dramatic, the geometry columns can be restored from shapefiles. I admit I don't know too much about postgresql, but maybe it is possible not to drop the geometry columns when uninstalling postgis and just leave plain binary data.
No, it's not possible. But it is possible to make them usable again by
replacing the input/output routines.
> > It's in the README file, under the section UPGRADING:
> > << PostGIS provides a SOFT UPGRADE procedure for minor or bugfix
> > releases, and an HARD UPGRADE procedure for major releases. >>
> I must admit I didn't read the README but stuck with the documentation:
> http://postgis.refractions.net/documentation/manual-2.0/postgis_installation.html#upgrading
> Maybe it is worth a notice that soft upgrade from 1.5 or prior is bound to fail.
>From the documentation page you link to:
<< PostGIS provides a SOFT UPGRADE procedure for minor or bugfix releases,
and a HARD UPGRADE procedure for major releases. >>
It isn't clear to you that 2.0 is a major release from 1.5 ?
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
