[postgis-users] Postgis 2.0 installation Problem - "undefined reference to `GEOSGeom_createEmptyPolygon'"
Alexandre Neto
senhor.neto at gmail.com
Thu Apr 26 07:29:50 PDT 2012
Lets see I have the enough strenght to fight it! :-D
Probably I will start by uninstall and purge GEOS, and start from the
beginning. And then other software might not work, that means I will have
to fight it too.
Thanks,
Alexandre Neto
On Thu, Apr 26, 2012 at 10:27 AM, Sandro Santilli <strk at keybit.net> wrote:
> > Something to do with more than one GEOS installed
> > The presented solution would be to change the order of "-L/usr/lib
> > -lgdal1.8.0" and "-L/usr/local/lib
> > -lgeos_c" in the makefile.
> > But in witch makefile?
> That solution is not very friendly, and more aimed at finding a solution
> in the PostGIS build scripts themselves than at solving your problem.
> Easier solution would be to keep a single GEOS around.
> You might have to fight your package manager, but that's the price to
> pay for freedom (don't let you package manager rule your machine!).
> --strk;
> ,------o-.
> | __/ | Delivering high quality PostGIS 2.0 !
> | / 2.0 | http://strk.keybit.net - http://vizzuality.com
> `-o------'
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120426/d6dc5ca0/attachment.html>
