[postgis-users] [?? Probable Spam] Re: multipolygon to single polygon
ju
julien.guilloux at ecrins-parcnational.fr
Thu Apr 26 09:02:59 PDT 2012
you can alss use a "with" statement as indicated by nicolas, but be
certain that what you want is to get the "sum" of all polygon of your
collection
bye
Le 26/04/2012 17:51, ju a écrit :
> ok so this is second solution.
> 1) fisrt count the number of objet of the collection
> select ST_NumGeometries(the_geom) as the_nb from YOURTABLE
> you will obtain the number of collection, so probably 4 polygon
> 2) then "explose" theses 4 polygon :
> SELECT
> what you want....,
> n,
> ST_GeometryN(the_geom, n) as geom_unique,
> ST_astext(ST_GeometryN(the_geom, n)) as geom_unique_txt
> FROM YOURTABLE CROSS JOIN generate_series(1,100) n
> WHERE n <= ST_NumGeometries(the_geom);
> note : 100 is default for serie, if you count 4 objet in collection
> you can write serie(1,4)
> you shoud obtain 4 rows, the text format is juste here so as you see
> the polygon coordinate
> 3) 2 choices
> 3.1 if one of the 4 polygon is what you want, then use it. for example
> if it is the n number 3 then update your table with
> update YOURTABLE set the_geom =
> ST_GeometryN(the_geom, 3)
> (dont forget a WHERE .... id of the row you want to update)
> 3.2) if you want to group all the 4 polygone to make a new one there
> are other possibility
> - for example make a table with the 4 polygons ( same query but
> "select into table" .....)
> with this table make a dissolve query to group the 4 objetc
> - update your table with the result of dissolve
> - you can also use array to group, etc...
> tip : sometimes it is quick to copy /past result wkt of query
> for example you copy the result wkt of the query for objet
> collection number 3:
> POLYGON((892426.5625 6463663,892432.9375 6463678,892434.4375
> 6463685,892454.75 6463802,892457.0625 6463879.5,892456.6875
> 6463879.5,892453.6875 6463931,892453 6463931))
> then you make a polygon with it :
> update matable set the_geom = ST_GeometryFromText('POLYGON((892426.5625 6463663,892432.9375 6463678,892434.4375
> 6463879.5,892453.6875 6463931,892453 6463931))'
> Le 26/04/2012 17:22, Mehmet Erkek a écrit :
>> Hi Juilen, thanks for quick answer.
>> I have 1 geometry and 1 row on the table. this geometry is
>> multiploygon which consists of 4 polygons.
>> I want to convert this mutlipolygon to one single polygon..
>> Any idea how I can do this?
>> I hope it is clearer now.
>> Thanks.
>> *From:*postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of *ju
>> *Sent:* 26 Nisan 2012 18:02
>> *To:* PostGIS Users Discussion
>> *Subject:* Re: [postgis-users] [!! SPAM] multipolygon to single polygon
>> not clear...
>> 1) if you have 4 polygons in 4 rows table distinct, this is not a
>> multi object issu. for this case use
>> dissolve to group polygone into only one, this is not a topic of dump.
>> 2) if you have 1 geometry and 1 row on the tablme, so this is a multi
>> object topic
>> you must sperate the differents objet of the collection
>> here : http://www.postgis.org/docs/ST_GeometryN.html
>> --Extracting all geometries (useful when you want to assign an id)
>> SELECT gid, n, ST_GeometryN(the_geom, n)
>> FROM sometable CROSS JOIN generate_series(1,100) n
>> WHERE n<= ST_NumGeometries(the_geom);
>> best regards, julien
>> Le 26/04/2012 16:27, Mehmet Erkek a écrit :
>> I have multipolygons which I would like to convert a single polygon.
>> is there a way to do this? please check the attached image. I tried
>> st_dump and afterwards st_union , but eventually I get a multipolygon
>> again, not polygon.
>> *Mehmet Erkek*
>> www.REIDIN.com <http://www.reidin.com/>
>> This message is for the designated recipient only and may contain
>> privileged, proprietary, or otherwise private information. If you
>> have received it in error, please notify the sender immediately and
>> delete the original. Any other use of the email by you is prohibited.
>> Please Consider the Environment Before Printing This Email
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net <mailto:postgis-users at postgis.refractions.net>
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Julien-Pierre Guilloux
>> Service scientifique - Géomatique
>> Parc National des Ecrins
>> Domaine de Charance
>> 05 000 GAP
>> tél : 04.92.40.20.10
>> fax : 04.92.52.38.34
>> julien.guilloux at ecrins-parcnational.fr <mailto:julien.guilloux at ecrins-parcnational.fr>
> Domaine de Charance
> 05 000 GAP
Domaine de Charance
05 000 GAP
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120426/a6fe2ab2/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120426/a6fe2ab2/attachment.png>
